I think we can VB6 barcode convert using "Text Box" function, Can any one guide me or explain on, How it need to be done.
- 126 reads
- 1 comment
Hi experts,
How stop printing in VB6 is possible if I only want to print a portion of a page then go to another position and resume the printing process ?
- 120 reads
- 2 comments
I need a VBS script that can monitor old folders and delete their contents when they are out of date. Please tell me how I can do this.
- 101 reads
- 1 comment
Hello experts. I’m using VB6 and MySQL in my project. I would like to know what function I should use in VB6 to filter specific records from a database. For example, when a user type in the search box ‘A’, all the row of a specific field that starts with letter ‘A’ will be available to user. How can I do that? Please explain it to me clearly on how can vb6 code filter records.
- 202 reads
- 1 comment
I want a Script in VBS to monitoring folder older than a specific date. I am using Windows XP, please help me by providing the Script. Thanks
- 202 reads
- 2 comments
I am about through with the Windows Visual Basic 6 and want to include my animated gif images. Will I be allowed to save images to animated gif VB6?
- 331 reads
- 2 comments
Hello Friends, I would like to know on How to use VBA to change file genre, Please provide sample coding or suggest the method.
- 126 reads
- 1 comment
Hi guys,
How to create a system print multiple images vb 2010? I need to make my own visual basic programming language system that will print multiple images; I don’t have any idea about the Gui and how to connect the system in to a printer. Just like connecting a bar code device to a department store system. I really need some advice.
Expecting some help, thank you.
- 134 reads
- 1 comment
How to show a file in vb open office hidden? I have two important software application in my computer desktop which is vb programming language and open office application. I saved all my database and Gui vb work in a specific folder together with open office files but when I opened the folders the data are not visible, how can I show those hidden files? I am using Windows 7 Os.
Waiting for your support.
- 89 reads
- 1 comment
Hi to everyone,
All about making payroll in vb to access. Is it possible to make a payroll system using visual basic programming language connect to a Microsoft Access database system? Please share and discuss with me your opinions so that I will be able to create this as a topic for my thesis proposal.
Your suggestion is very much welcome.
- 138 reads
- 2 comments
