Display :
Category: Visual basic
I am running Windows XP Operating System and trying to use Microsoft Visual Basic. I have installed Microsoft Office 2007 on my system and getting the following error message each time I enter or leave Excel. I uninstalled the software and reinstalled again but the error exists. How can I remove this issue? Thanks.
Hello Guys,
Is it possible to have VBA Macro recorder for AutoCAD 2012 as that of VBA Macro recorder in MS Word & Excel. I am used with the VBA Macro recorder in MS Word, Can anyone guide me about having VBA Macro recorder in AutoCAD 2012.
Thanks & Regards,
Athan Haas
Hello Techyv Members,
I need to know about, how to create time monitoring codes in VB6 ? Please suggest me the simplest, efficient and quick way of doing the same. If anyone help me by providing me a reliable source code for time monitoring, that will be awesome.
Please Help,
Zacharytyshawn
Hello Friends,
I am planning to develop an application in Visual Basic that will receive a .wav file path as input & display the sin graph with frequency and wavelength of the sound in the file. Please guide me about how to start creating Visual Basic sound frequency graph.
Thanks,
Abelina Sophia
Hello Techyv Guys,
I need to know, whether it's possible to use embedded Firebird Server in VB6, If so please help me the process of doing the same.
Thanks and Regards,
Young Hern
There is an Add-in that brings problems to Visual Studio. It is called the Tabs Studio and it allows automatic tab grouping. It pops up an error whenever Visual Studio is launched as shown below.
The Add-in Tabs Studio failed to load or caused an exception. Would you like to remove this Add-in?
If you choose yes, the file it was loaded from, ‘\\localhost\docs\visual studio 2010\Addins\TabsStudio.AddIn’,will be renamed.
Error message
Error number: 80131515
Hi Friends,
I need to merge two PDF with Acrobat VBScript, Please help me by providing the VBScript that will help me in merging multiple PDFs.
Thanks & Regards,
Brady Collins
I am using Visual Studio 2010 Professional using the Win 7 Professional. I am trying to run the C++ program using this system config but every time I get the following error message when I try to start the program. You can help me with the help of the attached error image below. Please provide any suggestion to fix this problem. Any idea would be grateful. Thanks.
D:\PortableApps\XnConvert\xnconvert.exe
The application has failed to start because its side-by side configuration is incorrect. Please
See the application event log Or use the command-line sxstrace. Exe tool for more detail.
I am just trying to install Visual Studio with Web Development feature but I am unable to install it properly because of this annoying error message. Provide the full instructions to install this program. I would be grateful to you. Thanks in advance.
Error
You must enable Visual Studio Web Development Feature in Visual Studio 2012 Or Install Visual Studio Express 2012 for Web before you can install this product.
To enable Studio Web Development Feature in Visual Studio 2012, refer to Visual Studio 2012 help.
I am just getting the following Microsoft Visual Studio error saying “Uninstalled exception at line 297, column 9 in Function code”. I can’t use this program properly. I have tried to reinstall the program to fix the problem but still exists the error. How can I solve the annoying error message. Help me. Thanks.
Uninstalled exception at line 297, column 9 in Function code.
0x80070002 – Javascript runtime error: The system cannot find the specified.
