The error I am getting is-2147024809 (80070057). The message is that 'there was a problem in a method of this object property range:
Microsoft Visual Basic
Run time error’-2147024809 (80070057)’:
There was a problem in a property/method of this range object.
How can I correct this error? Can it give me any details to complete this easily?
- 158 reads
- 1 comment
Hi, I have some important MS word files. I need them to encrypt in visual basic. So, can you please guide me how to encrypt a word in VB?
I need few design form in VB6 for entering student details. I just need images of the form, for me to refer to create a master form to enter the details of Students.
- 78 reads
- 1 comment
Hi programmers,
I am newbie in Visual basic. I found some sms sending software on the internet, but they are too much costly. So I decided to make a VB code to send sms from my desktop. Can someone provide me vb code for send sms to mobile? The program should be simple and easy to understand. I hope any VB expert will give me the code.
Regards
- 104 reads
- 1 comment
Hi, I am fresh to Visual Basic, Please get me an example Scoreboard using Visual Basic that will input the Name and Score and will display the Name in an order based on the score, Please help me to find a sample that match the mentioned scoreboard for quiz Visual Basic.
- 74 reads
- 1 comment
Hello Everyone,
I am a beginner in visual basic and i want visual basic ideas for programs.Please provide me some suggestions and ideas what kind of programs can i develop in vb which will help me learn creating codes in visual basic.
Thanks
- 78 reads
- 1 comment
I am working on a live wallpaper using Visual Basic wherein the colors change slowly in the image and go back to the original. To do this, I need to convert HSV to RGB, but I'm having difficulty with computation on the reverse process. I am trying to understand the explanation on Wikipedia but I need someone to better explain the process to me. Can someone explain how to properly convert HSV color to RGB in VBA, and can I use Excel to do the computation?
- 51 reads
- 1 comment
I'm trying to make a webpage which looks like the css menu amazon format. I would like it to have an easy user-interface. Can someone please teach me how to make css menu amazon which only relies on CSS/XHTML?
- 113 reads
- 1 comment
I have been working to migrate Data from ERP Software to Legacy System which is based on C# or ASP.net I have all data exported into excel format but it’s not possible to migrate all data in individually with different databases migration issues like issue of wrong data type format or any data losses, I want to do this through VBscripting. Is there any code for Vbscript to import excel into access?
- 203 reads
- 2 comments
