I have a little experience with Java and C# and none with VB.NET. I need to convert a code from Java to VB.NET and I want to know if there is a way to do that directly, without converting it from Java to C# first. Please tell me if there is a Java to VB.NET and C# converter that I could use.
Thank you
- 96 reads
- 1 comment
I have a list of web addresses and I need to convert these addresses to PDF. Can someone please tell me if I can find a Java to PDF online converter to do this task for me ?
Thank you
- 69 reads
- 1 comment
Under Windows 7, I have just installed “Microsoft Visual FoxPro v.5” and it’s showing in the default program file folder. When I go for accessing logging in as a standard user, I can’t open and access it. It shows me an error message like the screenshot. What can I do? Please help me here.
‘Microsoft Visual FoxPro
Visual FoxPro cannot start. Cannot create program workspace temp files..’
I have forgotten my password and I would like to set it and I want to send my personal information to this website but I am receiving this error message. Any idea please share it. Thanks
Problem: Sorry is not recognized as a user name or e-mail address.
I just installed Oracle Enterprise Linux 6.2. Before this I had 6.1 so I upgraded to the 6.2 version. At this time I am facing a problem in Drupal 7 install. An error message occurs during Drupal 7 install which you can see in the below attached image. Can anybody suggest me what should I do now? Thanks in advance.
Problem: Fatal error: Cannot redeclare render () in /var/www/html/includes/common Inc on the line 5757.
- 99 reads
- 1 comment
When I try to execute some codes, an error message appears. And the message says that it will continue to upgrade but the package could not be used. Please find the below screenshot for your reference.
Does anyone understand the meaning of this message?
Any help would be appreciated.
Thanks in advance.
Could not install ‘/var/cache/apt/archives/xfonts-base_1%3a1.0.0-5_all.deb’
The upgrade will continue but the package may be in a not working state. Please consider submitting a burgreport about it.
- 49 reads
- 1 comment
I am trying to install Total Annihilation version 3.9.01 Beta Patch but I am getting fail because of the following error message which occurs at the mid of installation. Does anybody know about it? Please help me regarding this issue.
Total Annihlation v3.9.01 Beta Patch Setup
Installer information
Could not access VBScript run time for custom action.
- 63 reads
- 1 comment
Using Microsoft APIs, I was working fine. Unexpectedly, the system shows me an error message as-
-I have created a new account on Microsoft’s site and yet I haven’t set any payment method there.
-An error message shows me while using the CustomerManagementServiceClient. GetAccountsInfo
My question is that-
Is the API call valid for only payed accounts ?
Is there any other way to recognize internal errors?
Please help in this regard.
- 60 reads
- 1 comment
Hello guru, I use MATLAB programming language to write a model simulate. When I try to run the model, an error message appears and it says that evaluating parameter is incorrect.
May I ask why this error appears and how can I fix the problem? I appreciate any suggestions. Thanks in advance.
sm_four_bar
- 109 reads
- 1 comment
I am getting an error while trying to establish a connection to the secure gateway; AnyConnect VPN client was not able to establish a connection to the specified secure gateway. Please try connecting again.
I have tried to connect again many times, I have also tried with rebooting the machine and but still connected to VPN was not established. The problem seems to be intermittent though, because it did connect, it has been just fine over the past few days. Can anyone assist?
I am running VPN version 2.5.0217 on windows Vista.
Cisco AnyConnect VPN Client
- 164 reads
- 1 comment
