How can I convert PHP4 to PHP5 file using PHP5 Script Pim software? I don't have PHP5 Script Pim software and I don't know how to use it. Please help with download link and clear instruction.
- 202 reads
- 1 comment
How can I add form in coffee cup for mac? Can someone point me any tutorial?
- 179 reads
- 1 comment
Hi Experts,
Have a look at the screenshot below. I received the error message while installing MSI silent. It is indicating the long path to short path failure in a directory. However, I installed MSI manually; running it from the same location as manual and it was working well.
Have you nay idea for the error message? Please help.
Thanks in advance.
QLDB2009 Network – InstallShield Wizard
- 148 reads
- 1 comment
I want to convert hex to float in delphi. What is function which we can use to create simple program hex to float in delphi?
- 248 reads
- 1 comment
I was debugging an FDT, it started building but doesn’t finish, a message appears. It has problem compiling. SWF is created and works when run manually but debugger doesn’t work.
What do I do?
Problem Occurred
‘Compile’ has encountered a problem.
An internal error occurred during: “Compile”.
java.lang.NullPointerException
- 340 reads
- 1 comment
We will be having an experimental presentations on our electronics class and i wanted to use the computer to send hexadecimal commands on com 1 to turn a light bulb on. Could somebody help me what commands should i input?
- 205 reads
- 1 comment
Hi, I need help. I need java loader MySQL to import my data into plain text. How could i possibly make this happen?
- 181 reads
- 2 comments
Hi, I'm into web designing and i want to make a menu which follows as you scroll down on webpages. Is there a way you could create menu following scroll?
- 206 reads
- 1 comment
I have recently downloaded the plugin eclipse color theme zend studio 9 and want to switch between 2 eclipse color themes. I like Oblivion and Modified Solari, is there a way I can switch between the two easily without losing information?
- 448 reads
- 2 comments
Which is better thin client SMS server or thick client SMS server? What are the advantages and disadvantages of each server?
- 278 reads
- 1 comment
