Hi experts,
I am new in website development. I am creating a webpage with login options. I don’t know how to create login page. Can anyone send me xhtml code for create login page? I shall be very thankful to you, if you help me out.
Thanks
- 46 reads
- 1 comment
Hi expert,
I am website developer. I am facing a problem with joomla manufacturing template. Everything was working fine in past, but now I have transferred to other host. It shows me an error that a XML file is missing. I am unable to find that which file is missing. While my template manager is working normally. Has anyone encounter such type of error? If you know the solutions then inform me.
Thanks
- 48 reads
- 2 comments
Hello,I have heard that Delphi is the best windows 7 tablet coding language .Brilliant GUIs can be developed with Delpi easily.My question is that where can I find syllabus of Delphi tutorials?Thanks
- 72 reads
- 1 comment
I am using eclipse rdf editor. I have installed Eclipse 3.5.2 in my system. I want to know that, Is there any log to find out about issues while running RSSOwl? Please tell me if it is possible and how to do this.
- 76 reads
- 1 comment
Good day!
I have a program built using Powerbuilder and uses MS SQL as its database, running on windows XP OS. I have a window that works as a date prompt. This window serves as an interface for the user to enter the date range of the report to be generated. It was working for about 3 months but just the other day it stopped functioning. I tried to use a message prompt to see if it is getting the correct date, on powerbuilder the correct date is being shown. But once it has been processed on the SQL side, the date becomes '1900-01-01'. Below are some of the codes:
- 173 reads
- 2 comments
I am very interesting of programming mobile phones and while net searching I have found that many programming languages are using for programming mobile phone? My question is what the best one is. And please tell me if we develop mobile software using C++ does it compatible with all mobile phones and how to test that software?
- 110 reads
- 1 comment
Is there any way who delivers a nice clean look to the html form style and makes it easier to follow? Can we align the fields and make the form labels bold with addition of CSS?
- 114 reads
- 2 comments
Hello Friends,
While working on asp .net I got this error while I start testing the developed webpage. Does anyone know whats missing in it?
Looking for some solutions.
Thanks for all help and support.
Microsoft Visual studio
Htmlfile: Unexpected call to method property access.
- 147 reads
- 1 comment
