I am trying to configure a PVR/Live TV for my computer.
Yes, I knew how stupid I am for trying to configure a PVR with these pieces.
I should have checked to see if the card's included software is compatible with x64 before opening and installing, but I didn't, and here I am.
Anyways.
I have tried DScaler; but it didn't work. Suffered a major memory leak and my computer froze.
I am trying to get GB-PVR to work. Not having too much luck with this. Only XMLTV.exe gets passed through local channels before flipping. I have no clue whether or not that is interfering with the Update EPG, but it probably is.
Is there any way I may get these to work?
Hi
I am having some issues with my eclipse during refreshing the project as shown in the attached error.
I think the main problem is that project is mostly forwarding by my tail after inserting the essential modifications in code and also in the jsps. We have 2 different versions of JDK jdk 1.5_11 and 1.6_11 I thought that might be the problem I uninstalled jdk 1.6 and reinstalled 1.5_11. But now I have come across another problem that is:
C:\Documents and Settings\dev3\Desktop>Java Test
Error: could not open `C:\Program Files\Java\jre6\lib\i386\jvm.cfg'
- 100 reads
- 1 comment
I wrote this code which I could use to download an excel file from a particular location;
- 45 reads
- 1 comment
Hi programmers,
I am developing an Android app for smart phone. I need some help from Android developers. I wish to display progress circle icons when my apps are busy or uploading some information. May I need to create animation or Xml file for it? Can someone provide me the edit able code for this purpose? Please share your ideas and tips.
Thanks
- 73 reads
- 1 comment
I want to develop an Android app with graphics.
I think it's easy to come up with a better design with Corel draw.
So how can I use Corel for Android?
Help me experts.
- 45 reads
- 1 comment
Hi , I want to get a little idea about billing programs.
I have to complete a billing process.
How to write billing programs in FoxPro?
Is there any FoxPro experts?
Help me. Thank you.
- 107 reads
- 2 comments
Hello experts,
I am developing a web page by using Wordpress. I want to know about the problems and their solutions before starting my project. That’s why I am searching for wordpress pingbacker related blogs. Please share the best blogs related to this issue. Thanks for sharing your kind information.
- 60 reads
- 1 comment
I have referred many books but I have not got any clear answer to this question. Everywhere they have just brought to the attention that the PLO is the best and all, and why, and what benefit or cannot seem to be clearly defined.
So anyone can you please elaborate it better:
Or
If you give be a link to an article / book on this topic, it is essential that there is an example which will show this benefit. I just cannot understand how to apply the classes to the programs. I am writing while programming C + + Builder so far, because the newer version 6 Builder will not go until you know what it is, but it will be C (C + +, C #) I think it will be 99%. So I want to see benefit with the examples,
- 135 reads
- 1 comment
My request for support from more skillful associates, as I am unable to realize the following query.
The query is:
The formation of certain roles PL / SQL, which, by means of a cursor variable to be read two records of a database table and the next two, will transfer to the caller program in which that will be shown.
Function code I am getting in the following manner:
CREATE OR REPLACE FUNCTION used type REF CURSOR is KURS_MAIN_TIPS;
kurs_1 KURS_MAIN_TIPS;
kurs_1 RETURN IS raksts kurs_1% ROWTYPE;
I number; BEGINOpen kurs_1 for select * from club; for I in 1 .. 4 loops fetch kurs_1 INTO racists (I); DBMS_OUTPUT. PUT_LINE (racists (I));
- 289 reads
- 1 comment
