Display :
Category: Others
Category: Others
Hi guys,
I am going to create sample slide shows movie maker for windows. The problem is that the images what are supposed to be used are scattered in different folders. I had created a new folder containing all the images but I need the correct order of display and rename them sequentially. What is the quicker processing?
- 92 reads
- 2 comments
