Display :
Did not find what you want,
Be the first to ask question on Others
Category: Others
Which are the various memory allocation techniques used? Why are the used? What is the different between the various methods of memory allocation?
Category: Others
What is the meaning of direct memory access technique? How does it access the data? What are the advantages of using a Direct Memory Access method?
Category: Others
MediaTek’s new Helio X-25 10 core chip has Meizu Pro 6 which has 6GB RAM. What are its advantages? What is it? What are its features? What are its differences compared to X20?
Category: Others
What is the difference between the main memory, cache memory and virtual memory? Why do we need each one of them?
Category: Others
In recent times, WIFI has become the most essential part of man’s life, more than food, shelter or water. What is this WIFI? How does it work?
Category: Others
What do you mean by the term Data Abstraction used in DBMS? How is it useful? Why is it used? What are its advantages?
Category: Others
What is the purpose of anti-junk email software? How is it helpful in protecting the security of our email account? Is it successful in providing protection? What are its advantages?
Category: Others
Google has introduced a new method of tracking a location with the help of artificial intelligence and an image of that location. How does this technique work?
Category: Others
According to recent studies, computers can tell if the user using the computer is bored or no. How is it capable of doing so? How does this feature work?
Category: Others
In operating systems, there is something called as a backdoor. What is it? What are its uses? In what way is it helpful and if possible, how can it harm the computer?
