Hello
I use the VIPM2011 edition as well as LabView2009 edition. I have organized all the necessary ports.
When I try to set up the Arduino Labview pack, one Test window gives me this error
"PLEASE VERIFY VI SERVER".
Here are the screen shots of the window of LV, VIPM and the error message pop-up.
Please help me to solve it.
Thanks a lot.
- 231 reads
- 1 comment
Hello experts
I was attempting to modify its LAN IP setting as well as I used to acquire to my nsm2 GUI web address by visiting to 192.168.20.20.
As a result I made a decision to modify it to 192.168.168.20 as a result it is able to be in the similar subnet as the unique Access point. And AP IP was in there and it still is 192.168.168.32 (also my setting of WLAN was 192.168.168.60 .255.255.255.0 as well as gateway: 192.168.168.1) and till now it should be same cause just i have changed LAN IPS.
- 173 reads
- 1 comment
Hello
I got the section you had mentioned however when I tried to click on certificate, I find an error message:
- 237 reads
- 1 comment
I have downloaded the most recent update for Sage ACT!
I am using ACT! And 2012 Premium as well as an HTC EVO Shift 4g.
This result for the PC (Windows 7) fails. Moreover, Outlook 2007 don’t sync with ACT! So, I need a solution of this problem. Please help.
Error
Could not load file or assembly
'Act.Framework.BusinessLink.LinkConnector, Version=12.1.181.0,
Culture=neutral, PublicKeyToken=ebf6b2ff4d0a08aa' or one of its
- 166 reads
- 1 comment
I am running Act Premium 2012 as well as Vista Home Premium.
When I am attempting to launch the Sync Service, I got that I don't have any authorization to act so and I need a Windows Administrator authorization etc....
But I AM the Administrator of Windows. I can't look like to get anything to "Run as Administrator" to begin it.
Need a solution. Thanks.
ACT!
Sage ACT! Network Sync Service error. Requested registry access is not
- 134 reads
- 1 comment
Can you please help me out with this problem? My purpose for installing deepfreeze program in every computer in my LAN house is for it to stay protected against various viruses and Trojans.
But when I already decided to enable the program a message like this appeared,
SuddenAttack
System has failed to prevent an illegal program to be executed.
Please restart your SA and try again later.
- 308 reads
- 1 comment
I wanted to know whether there are any plans for Trillian to be supported by adding LCS 2005 / OCS 2007 support. I know that to do so, the support will need to be included right at the core.
Is there any development in this side lately? The OCS/LCS plugin was broken for windows client recently, and there is no plugin support for the Mac version Trillian.
- 189 reads
- 1 comment
In my new firmware, everything was working fine when I tried using ACL to set a roaming profile on QNAP until the connection to web interface was lost with AD. I tried to refresh bud didn’t work. QNQP doesn’t remember my Active Domain user’s on files, but I must somehow connect to Microsoft networking.
When I visit the domain users in qnap management, I’m getting a blank screen. Then the NAS was reconnected to the AD. I’m able to see Manager: owner 3002 when I use webfile manager.
MS ACL = unix3002 or unix user
MS ACL = Domaine + none
Can somebody tell me why my connection is failing and why my qnap is not remembering my files at AD
- 120 reads
- 1 comment
Hi friends,
We are currently conjunctively using CA Arcserve Backup v16 and Arcserve D2D v 16. The archserve software needs a login which is compatible with D2D service account for successfully backing up with the software. The backups are on QNAP box on simple share.
If such a login is not used, the error message that we receive is “RC=1314, A required privilege is not held by the client.” Is it possible for me to login as http://qnapaddresshere WebUI using a domain account?
I think that this would bring an end to all our problems. Another thing I noticed is that the changes I do in AD are not getting updated by lansweeper.
Please help me.
- 421 reads
- 1 comment
I have recently installed 10.7 and tried both upgrade install mode and fresh install mode, but now I’m unable to get connected to my domain. The error message that I’m getting is “Network accounts are unavailable”.
I have found that the domain controller was able to be pinged blindly. The machine was recognized by the computer account corresponding to Active Directory.
The computer gives me a message asking if I wanted to join the existing account.
Can somebody help me with this please?
- 142 reads
- 1 comment
