Hi, Guys! I am an architect Engineer. I have to make some blue print for any type of construction or system. I feel very complexity there. So, I have decided to use a SOA conceptual architecture diagram. It will help to show the big-picture architecture in one diagram. Please anyone give me information of SOA diagram tools
Hi, Experts! Actually, I am looking for dedicated server for maintaining Linux operating system. I have visited in "Host Gator". Can anyone give me perfect solution for choosing the best pack of Linux dedicated server hosting?
- 54 reads
- 1 comment
I have got zeroshell and it is working well for me. Nice effort but now there is a problem with dens update. As I have tried to change the firewall setting and set the output chain but nothing works. Am I supposed to do something else to allow opendns updater connect to host? Please solve my problem
- 117 reads
- 3 comments
Can anyone provide information on how to simulate slow and congested links between nodes on the network using an inexpensive Linux Delay Simulator?
I want to create delay simulation profile in a way that delay should only apply to connections according to the filter criteria for testing.
Thanks!
- 120 reads
- 1 comment
Hi there! I want to create a Linux hdd script random read. I will need this to test the drive capabilities. Which I can use in maintaining the server. Is it safe to make such script? Thanks in advance.
- 95 reads
- 1 comment
Hi there! I've used Linux for a while and forgot the command. I want to rejoin split pages to continuous page. Experts, need urgent help with this. Thanks in advance.
- 54 reads
- 1 comment
Hi Friends,
I came to know about Bluesoleil para Linux software. Can anyone tell me about its Features and Functionality?Please tell me also system requirement to install this software.
- 70 reads
- 1 comment
Hi.
I looked for 10-Strike Network Monitor 2.4 version for mapping networks.
But the problem is I could not find such a Network Mapping GUI software in a Linux environment, which has similar features in the 10-Strike Network Monitor.
Please help me.
- 46 reads
- 1 comment
Hello, I’m using laptop ASUS A42JC with VGA NVIDIA optimist that can be switched to on board if the add on VGA is not needed. I have dual boot operating system with Windows 7 and unbent 10.10 Maverick installed in the laptop. I have no problem with the VGA with Windows 7 but the real problem lies in unbent. I have installed all the needed drivers but the only driver not installed yet is the VGA driver. I have received recommendation from unbent. So I did install them, and as usual after installation completed I restarted the laptop. After restarted, I cannot use unbent GUI only can access terminal. I'm confused I thought I installed the recommended driver for the VGA but why did it fail?
- 113 reads
- 2 comments
- 109 reads
- 1 comment
- « first
- ‹ previous
- next ›
