Display :
Category: Mobile Hardware
Considering HTC One M9 and Sony Xperia Z3, which of these two smartphones has greater and special features with respect to size, model, and pixels of the camera phone? In terms of the various weather conditions pertaining to these smartphones, which of them promises durability and optimum qualitative performance? Thank you.
Can one know the very likely encounters or operations that cause smartphones, tablets and all general phone types to overheat? Are there some particular operations or functions of the phone which can cause overheating? What are the much recommended solutions to overheating? Francis Otabil is my name and a third year student of Catholic University in Brong Ahafo Region. Thank you.
Hello everyone! Since we all know that selfies from smartphones have become very common these days, now we see selfie sticks as well which can be used to take picture of a big group. My question is how does a selfie stick work? Since it is so generic and it can be used by every smartphone, how does it actually communicate with the phone and make sure that the picture is taken at the right time? I mean if there is a button in the stick, what exactly does it do to tell the phone to capture a photo?
Hello! I am using Motorolla XT615, not a very new smartphone. I have used it for quite a long time now but now it is showing all sort of problems. One problem is that it always shows that memory space is insufficient while downloading something from playstore. I even went to the settings and checked there was no application which was installed on SD card. Due to this I actually had to delete a lot of applications and photos from my mobile phone. I think that automatically the setting has been changed that whenever I download something it is stored in the phone's memory rather than in the SD card. Please help me fix this problem
Hi everyone! I am thinking of purchasing a Nokia phone but right now I cannot decide which one is the best among the following: Nokia Lumia 530, Nokia Lumia 630 or Nokia Lumia 730. I am comparing these models in terms of technical specification. Kindly guide me properly. Thanks in advance!
Hello all, recently I had to record some voice using android phones. I had two android phones and I had to record the conversation of a meeting. There were about 15 people in it and I placed one phone at one end of the corner and the other on the other end. I was successful in recording the meeting properly. Now the problem is that I need to merge these two recordings into one recording. What sort of software should I use? Please Help! Thank You!
Hello all, I use an android phone. I have noticed that whenever I use my smart phone with an SD card, there are some .exe files with same name as the name of the folder. Like in the folder named backup, I found a file named as backup.exe. This is true for all the other files. I don’t know if these files are useful or not. If these files are useless, please help me to get rid of these files. I just hope it is not a virus of some kind. Thanks!
Hello everyone! I am using Samsung Galaxy S3 and I have been using it with my car’s Bluetooth for quite a long time now. But recently it stopped working anymore. Whenever I try to call, the call drops just after 2-3 rings but I can still see that the call is not dropped in my headset. Please help me with it. Thank You!
Hello everyone! I was thinking if its possible that I can run and compile the Java and Android programs within my Android Smartphone. I mean its possible to compile and run programs using the Android Development Toolkit on my laptop or a desktop. So in the same manner, is it possible for a Smartphone as well? Thanks for the help!
Hi everyone. I am using Samsung Note 2 and yesterday it went for an automatic update online. After that it has been behaving abnormally for no apparent reasons. All my applications are crashing; the camera is not working properly. The device gets stuck very often for no reasons. I cannot view videos and listen to music anymore. Is it possible for me to downgrade my device and use it in previous version? Please Help! Thank You!
