Display :
Hi there,
During the install of Microsoft Lync Server 2013 this error message box appeared and I had to click OK hoping that the install will continue, but it didn’t. Any solution ? Please an expert help me please to install this properly.
Thank you !
Microsoft Lync Server 2013, Debugging Tools installation or uninstaller requires that Microsoft Visual C++ 2012 x64 Minimum Runtime – 11.0.50727 Package is already installed. Either use Setup.exe for installation or run vcredist_x64 included with the product to install the redistributable.
Hi there,
This morning when I tried to log into my Windows Live Messenger this error appeared. I never changed my password since I have this account and now it seems is not working. I can’t change my password because I forgotten some data about my account. Is there any way to fix this ? How can I solve this error?
Thank you !
Windows could not sign you in because your password is incorrect. If you have forgotten your password, click Forgot your password ?
Error 80048823
Ok Help
Hi experts,
When I want to connect to an online meeting I have the following error. I don’t have a solution for this and nothing that error say is not working. What steps should I follow to repair this ? What is wrong ?
Thank you experts !
Microsoft Lync 2010
Sorry, something went wrong, and we can’t get you in the meeting. It’s possible you’re using a bad URL. Try calling into the meeting using the phone number on the invite, or ask the organizer to drag you in.
Hi there,
I try to install Lync 2010 RC on a machine in a domain that already runs OCS 2007 R2 and it gives me this error and warnings. I don’t know how to read this error and how can I solve this so is there an expert online that would like to help me please ?
Thank you !
Creating new log file”C:\Users\baluilag\AppData\Local\Temp\Install-CSAdServerSchema-7b0835e1-0529-4b6e-9288-51af2aa00159.xml”.
Modify the Active Directory schema to support Lync Server 2013.
Hello experts,
I try to build a complete new Lync 2010 Enterprise and get this error after running the Prepare Schema option in the Deployment Wizard. I don’t know what I did wrong and how can I solve it. I’ve followed all the standard steps and still. Any solution ?
Thanks !
Error: The user is not member of “Schema Admins” group.
Hi there,
Lync Server 2013 gives me this message and I don’t really know what it means. I know that is not working anymore with all functions and I cannot start them. Does anyone have a solution ? What I did wrong and what is limiting the capacity ?
Thank you !
Lync Server 2013
Monitoring Dashboard
Report processing stopped because too many rows in summary tables are missing in the call detail recording the LcsCDR database.
Hi there,
I don’t know why but for 2 day I cannot sing in to Lync. I have this error and I don’t know how to manage it. I have updated Lync to the latest version and also my PC is updated. Any solution ? My Internet connection is good so what could be the problem ?
Thanks !
Cannot sign in to Lync
There was a problem acquiring a personal certificate required to sign in. If the problem continues, please contact your support team.
Hi there,
Call was not completed is my new error from a long list that I have. Most of them started to appear after I did an update for my Windows XP and I don’t have any solution for this. Can anyone help me please ? What should I do ? Should I reinstall Windows XP ?
Thanks !
Call was not completed or has ended.
When contacting your support team, reference error ID 52063 (source ID242)
Troubleshooting information is available online, including best practices for using Lync.
Lear More
Hello there,
I have installed Lync Enterprise and SQL Developer Edition each on a virtual server and I have this error when I want to publish the topology. I don’t have big experience with this kind of errors so is there anyone who can help me please ? Why I cannot publish the topology ?
Thanks !
Publish Topology
Topology Builder encountered an issue and cannot publish this topology.
On my laptop are created 2 users account and mine is the administrator. I have this error when I want to launh Lync. On the another account the program is working just great without an error and it doesn’t have admin rights. Can anyone help me please with this ? Why on my account with admin rights is not working ?
Thanks !
Lync has both per-user and per-machine instances installed. Click OK to remove the per-user installation.
OK Cancel
