I was working on “Microsoft MapPoint” and suddenly I received an error message like the one in the screenshot. Can you help me please? I need to get a proper solution.
“Microsoft MapPoint
Your registry settings for this application were not copied correctly. To correct these settings, run Setup again for this application from the location where you originally installed it.”
I’m getting an error message like the one given in the screenshot. Can anyone solve the issue please?
Lync
Cannot sign in to Lync
Cannot sign in because the server version is incompatible with Microsoft Lync2010. Contact your support team with this information.”
- 74 reads
- 2 comments
I received an error message like the one given in the screenshot. Can anyone help me to solve the issue please?
“Lync
There was a problem verifying the certificate from the server.”
- 52 reads
- 1 comment
While working on Microsoft InfoPath an error message occurs like the one given in the screenshot. Can anyone solve the problem please?
‘Warning
There has been an error while processing the form.
Click continue to resume filling out the form. You may want to check your form data for errors.
Click Start Over to load a new copy of the form.’
- 49 reads
- 1 comment
While using Microsoft FrontPage, I receive an error (shown in the screenshot) when I go to delete a certain folder or file. How can I solve the problem?
“Error Deleting File or Folder
Cannot delete Folder: It is being used by another person or program.
Close any programs that might be using the file and try again.”
- 58 reads
- 2 comments
While working on constructing a web page in “Macromedia Dreamweaver, I received an error message. Can anyone solve the issue?
“Macromedia Dreamweaver MX
The desired action could not be completed because an unexpected client/server communication error occurred”
- 35 reads
- 1 comment
I was working in Microsoft Entourage. An error message (like the screenshot) appeared and it stopped working. Can anyone please solve it?
“An unexpected error occurred while trying to load the Microsoft Framework library.”
- 49 reads
- 1 comment
I was working in Microsoft Entourage and suddenly an error message (like the screenshot) appeared. It stopped working. Can anyone please solve the issue?
‘Error Description
Error
Quit and restart Entourage. If this problem continues you might need to verify and rebuild the Entourage database.
Explanation
Could not retrieve mail
Account name: “Hotmail”’
- 44 reads
- 2 comments
How can I fix this error?
Error 1935.An error occurred during the installation of Assembly
'ADODB, Version='7. 0.3300.0", PublicKey Toke='B03F5F7F11D50A3A", LCID="3081", GUID="ef53050b-882e-4776-b643-eda472e8e3f2". Please refer to Help and Support for more Information.HRESULT:0x80131047
- 125 reads
- 2 comments
What does the error “You can only add project references to other Silverlight projects in the Solution” exactly mean in the add reference option for Silverlight?
- 83 reads
- 1 comment
