I am doing some testing with AD Import tool but I am getting erros when specifying my domain controller and logon credentials. I have v6.0.23 (SP1) and it has a localhost EMS license.
Here is the error I get;
"There was a problem trying to connect to domain controller. Following error occurred: The specified directory service attribute or value does not exist."
- 69 reads
I am getting this error code 0x800ccc90 and I need a help for this.
Here are more details on this.
I got some feedback from Windows Live assistant named Glenda. She said me to send a snapshot of the error but my system did not let me upload as she wanted. I have windows live 2011 essentials.
- 12 reads
I was using the Template Wizard in Microsoft Dynamics AX 4.0 to export a table that contains a "Real" field type to Microsoft Excel. When I did this then the following error message displayed. I tried my best to resolve this error but couldn’t so I need your help to resolve this problem.
I am trying to open the Microsoft Dynamic CRM Webpage but it gives me the “Access Error”. It says the system could not log you on. Help me to resolve this error as soon as possible. Any help would be appreciated.
Access Error
Hi experts,
I have Qt5 with MSVS2013 32 bit and doing a threading application. When I run the program after some time I received the following “Debug error”. Do you have any idea about this error? Suggest me possible solution.
Debug Error!
- 63 reads
- 1 comment
I am using Windows XP SP3 have been trying to install Microsoft Visual C++ 2010 on my machine, but it always gives me the failing error even I downloaded redistributable from the Microsoft Website. I also tried it on Windows 7 32 bit but have the same issue. Suggest me with possible solution.
I am in trouble using Excel while I was trying to connect to excel as a data source and suddenly an error message appeared. I can’t understand to resolve this matter. The error message appeared as followed. I really need your help to fix this issue.
- 22 reads
- 1 comment
Hello experts,
I have installed Windows XP, SP2 and when I attempted to install Microsoft Cluster Server Setup I received the following error message. I restart the computer and attempted to reinstall the setup but the same message shows given below.
Microsoft Cluster Server Setup:
Hi everyone. How to create or add a flash banner in email signature? Where can I download a software for this flash banner in the email signature? Thanks for helping.
- 71 reads
- 2 comments
Hi. I'm a user of flamingo next 2012 but I'm having troubles. Why is flamingo nxt 2012 not working on several templates in my control panel materials? Thanks for a lot.
- 55 reads
- 2 comments
- « first
- ‹ previous
- next ›
