Display :
I had a version of Office 2010 installed on Windows 7. I uninstalled it and now I cannot install any other version of Office 2010 because whatever I try I cannot delete a registry folder. I tried various registry cleaning programs but without any results. What options do I have besides to reinstall Windows?
I was working on “Microsoft Office InfoPath” and I received an error message like the one in the screenshot. How can I solve the issue?
This form template has errors which may prevent it from functioning correctly
This form template has errors which may prevent it from functioning correctly.
To ignore the errors and continue publishing, click Ignore Errors. To cancel publishing and review the errors, click cancel.”
As I install Microsoft Office on my computer, I get this error message:
The Installation of Microsoft Office 2010 requires that MSXML version 6.10.1129.0 be installed on your computer
Can someone here enlighten me on what this specific error message from webpage error is referring to? I cannot submit the form because of this and I need this to get fixed.
The form cannot be submitted because of an error.
“The form cannot be submitted because of an error.”
Please help. Thanks in advance.
Why does this error message appear during Setup? How to fix it?
Error occurred
A previous installation has been detected with a license type that does not match the install in progress.
I cannot utilize properly the Microsoft Word installed in my computer because of this problem: An error occurred and this feature is no longer functioning properly. Please run Setup and select "Repair...."to restore this application.
How can I fix this? I have tried to Repair it but it still did not seem to work.
In the “Resolve Errors” dialog box, I attempted to fill the “Your changes” with the word “Testing” but it says that “Testing is not a valid entry. Please try again. For this error, you can retry or discard your changes. If you have multiple conflicts or errors, you can also retry or discard your changes.” Will I also receive this error if I try using a different word?
Failed to parse RSS feed."Invalid XML. Error on line 114.The element type "meta" must be terminated by the matching end-tag"</meta>"."
How to fix this error?
Error on line 114.The element type &quot;meta
As I attempted installing Microsoft SharePoint Server 2010 but it was not successful due to an error which says,
Sharepoint error
The install in progress conflicts with a previously installed Microsoft Office 2010 Server product.
I have tried basic troubleshooting and also uninstalled MS Office 2010 Server but this still occurs. Any solution?
What does this means and how to fix this?
The ActiveSyncDevice exchangeserverpro.net/Company/HeadOffice/Users/Mahera.Bawa/ExchangeActiveSyncDevices/iPhone$Appl87941C1N3NS cannot be found
