Hello People,
For me the Microsoft’s flexible but the annoying platform, SharePoint make both very easy and difficult. For example, some of my clients using Office 2013 had problems opening a certain folder in Windows Explorer; they encountered an error message in regards to contact the administrator to receive permission access when they tried to write code that manipulate documents in SharePoint.
Windows cannot access
You do not have permission to access.
Contact your network administrator to request access.
Thanks for the help.
- 66 reads
- 1 comment
I have Visual Studio 2012 RC installed on my computer and I also recently installed MS Office 2013 but got this error message below when I started my Visual Studio, I later realized that the error was as a result of C++ runtime conflict between VS2012 and Office 2013, any ideas of how to solve this?
The procedure entry point-Atomic-fetch-sub-4 could not be located in the dynamic link library D:\Program Files(x86)\Microsoft Visual Studio 11.0\common7\IDE\devenv.exe
Please help.
- 77 reads
- 1 comment
I am using windows 7 fresh installed on my desktop, now I am trying to install Office 2010 its giving an error saying that to uninstall previous version of Office. But I never installed office package.
Microsoft Office Professional Plus 2010
Setup is unable to proceed due to the following error(s):
Microsoft Office 2010 does not support upgrading from a prerelease version of Microsoft Office 2010. You must first uninstall any prerelease versions of Microsoft Office 2010 products and associated technologies.
Correct the issue(s) listed above and re-run setup.
I have the copies of MS Office 2000 & 2003 & 2007 & 2010 I used to setup normally with other windows till now no problem accorded. But now only MS Office 2003 is getting installed properly. When I try to install Microsoft Office 2000 & 2007 & 2010 its giving an error
Please give me an answer or solution
Thanks
Microsoft Office Professional Plus 2010 encountered an error during setup.
The Windows Installer service cannot update one or more protected Windows files.
- 132 reads
- 1 comment
I tried installing Office 2013 64bit in Windows 8 Enterprise Evaluation x64 with this setup: X17 Setup.X64.en-US_O365HomePremRetail_90f18966-ae87-4831-a944-7e58f8f7e176__TX_SG_.exe but encountered this error.
We’re sorry, but we can’t verify the signature of files required to install your Office product.
We need to verify these signatures to keep your computer safe. Please retry installing product or, if installation continues to fail, try re-downloading your installer if you got it online. Make sure you only download Office products from a trusted source.
- 95 reads
- 1 comment
Hi Experts,
I tried installing a 64bit Office 2013 Home Premium on my computer but encountered this error message that Office 2010 is existing already, I this that they should coexist both of them. Any ideas how to solve this?
We can’t install the 64-bit version of Office because we found the following 32-bit programs on your PC:
Please uninstall all 32-bit Office programs, then retry installing 64-bit Office. If you want to install 32-bit Office instead, please run the 32-bit setup.
Please help.
- 90 reads
- 2 comments
I have installed office 2013, now if I open any application, it won’t start. Instead of it it’s giving errors. I have reinstalled the application then I am getting more errors for some or the other. I have very horrible experience with Microsoft`s products:
Office
Error
We are unable to install fonts
Office
Couldn't uninstall Office
We're sorry. Office couldn't be uninstalled.
Please try uninstalling Office again.
- 70 reads
- 1 comment
Hello guys,
I recently purchased Samsung Galaxy Tab. I am very happy to own it. I want to use Microsoft Mappoint with GPS locators on my tab. I am searching for microsoft map point galaxy tab. Tell me how can I install and use it on my galaxy tab. I need a simple and easy way for this. I hope you can easily understand what I want to say and what are my requirements.
Thanks
- 120 reads
- 2 comments
Hello People,
How will Microsoft Office 2013 or Office 365 integrates with QuickBooks? I tried a test of Office 365 with the latest version of QuickBooks, QuickBooks Enterprise 2012 R9 and encountered some problems. And when I try to integrate Excel with Quickbooks and update the spreadsheet within QuickBooks, I got the error message below:
And when I try to integrate it with Word, I experienced a problem in the process, I got the error below:
- 199 reads
- 1 comment
Hello Friends,
I am running Windows 7 SP1 Pro with a full license and I tried to install Office 2013 from the "Setup.X86.en-us_O365HomePremRetail_ab23b275-f32c-4784-b74b-20fd415646b8__TX_DB_.exe" but encountered this error “You need to get a modern version of Windows" However when I tried using a different installer, I encountered another error 1310 and even though I have full Administrative Rights.
Does anyone know why this is happening?
Thank you very much.
- 67 reads
- 1 comment
