Hi. I have a problem with my MS Office Professional Plus 2010. During the process of installation, I have received an error message which says:
“Error 1935.An error occurred during the installation of assembly component {89EDD3A9-944B-3257-8484-D6EB6A00DDF5}. HRESULT: 0x80070BC9”
Any help, please? Thanks.
- 81 reads
- 1 comment
I got Microsoft Office Professional Plus 2010 for my personal computer. I have Windows 7 Home Premium 64 bit. While I attempt loading Office I receive an error message which you can see at below attached image. I need your help to resolve this. Thanks in advance
Problem: Error 1920. Service ‘Office Software Protection Platform’ failed to start. Verify that you have sufficient privileges to start system services.
- 198 reads
- 2 comments
Currently my OpenERP Client-Web server is connected to a remote OpenERP server. When I intend to export all Base Object Models BOMs, an error appears and please find below screenshot for your reference. However, same operation in Local database could be applied to the web client; the operation is working properly while the remote production database does not work.
Could any expert have some suggestions to solve this? Thanks in advance.
Error server:
404 - File not found or repertoire.
The resource you find has been can be deleted, renamed or temporarily unavailable.
Hello, zip file named openerp_report_designer.zip is installed into OpenOffice and base_report_designer module is installed into OpenERP. However OpenOffice could not be connected and the error message appears and says that the group is not found. Please find the error message screenshot for your reference.
Does anyone have an idea how to solve this error please? Thank you very much.
Group name Error
Group not found!!! Create a group named: "OpenOfficeReportDesigner"
- 114 reads
- 1 comment
Hi!
I was trying to install MS Office 2007, but during installation process I faced an error with some weird characters with a startmnu 2714 error. Also I cannot uninstall my office 2003 either.
[I am attaching an error screen shot with my question]
(startmenu)
Setup failed. Rolling back changes…
Please help me out of this anomaly.
Thanks in advance.
I am attempting to Uninstall Microsoft Office SharePoint Server 2007 from my control pane but after 30 seconds of uninstallation process it gives me an error message. In the attached image you can see the entire error message. I need assistance. How can I uninstall this from my computer?
Thanks
Error 1920. Service “W3SVC” failed to start. Verify that you have sufficient privileges to start system services.
- 74 reads
- 2 comments
I installed the DL19837065, I noticed the Vault 2013 Add-in for Microsoft Office Application was not working as the icon was grayed out and got this error message “Could not load file or assembly 'Autodesk.DataManagement.Client.Framework.Vault.Forms, version=17.0.0.0, Culture=neutral, PublicKeyToken=aa20f34aedd220e1' or one of its dependencies. An attempt was made to load a program with an incorrect format.”
Any solution to the problem?
I run Window 7 Pro x86 and I already installed Office 2007. I tried installing Office 2013 Preview which I downloaded from Technet:http://care.dlservice.microsoft.com/dl/download/4/7/1/4712B4E1-4DD9-4468-B8A4-507D7F988B1F/professionalplus_en-us_x86.exe but got this error. Even after several attempts including running it as admin still got the same error.
Any ideas how I can fix this?
- 99 reads
- 1 comment
Please help me resolve this. I tried installing Office 2013 Preview which I downloaded from this Link on my 32bit Windows 7 Ultimate but got this error.
Thank you in advance.
Setup cannot continue because a required file is either corrupted or not available. Run Setup again from the original source disc or download location.
- 91 reads
- 1 comment
Hi Experts,
You will get this error message “The procedure entry point _Atomic_fetch_sub_4 could not be located in the dynamic link library c:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\IDE\devenv.exe” when you try to load your Visual Studio 2012, after installing Office 2013 on the same computer, because Office 2013 breaks Visual Studio 2012.
Looking for some solutions.
