Display :
File not found 30020 The file could not be found.
I received an "Installation Error: File not Found" error message when I tried to update Office 2003 programs from the Office Update Web site or the Office Download Center.
I really don’t know any other simple way to make it work so if someone who could give me a detailed instruction would be a big help.
Thank you very much.
Command Failed 30008 One or more required Office components failed to complete successfully. For more information, consult the setup log file.
I am getting an error when installing SharePoint Server 2007 Sp2 Trial version. Here is the errors content, first the message from setup and next the error log info that contains the error:
Microsoft Office SharePoint Server 2007 Trial Setup
Event Type: office12setup     P1: {10120000-1f00-0000-0000--0000000ff1ce}
P2: 12.0.4518.1014     P3: x     P4: command failed
P5: lhpsrv_lpsrvwfe.xml     P6: x     P7: x
I have been trying to activate my Microsoft Office 2010 programs but still I am receiving an error. How can I resolve the Microsoft project trial activation error? How can I also tell if my software has been activated? Please help. Thanks.
I decided to uninstall Office 2013 Preview, but it somehow affected other components of Office 2010.
Now, I can no longer open PPT/PPTX/PPS email attachments on Outlook 2010. I can still preview the file on the e-mail, and I am able to save it onto the computer to be opened.
When I open attached PowerPoint files I receive a pop-up prompting me to repair the file. When I click OK, another pop-up comes along and says an error has prevented me from accessing the file.
I have attached the two errors in the screenshots below. . I am on the debating on reinstalling everything on my computer, not just Office 2010.
Thank you for any support you can provide on this matter before I go through with this.
Hi There,
I just added the .xsd schema to a VSTO word template (Office 2007), and I also enabled the document action pane. When Iran it I received an error message, I need an interpreter for this so I posted it below.
What would I have to do to get it to run?
error HRESULTE_FAIL has beenreturned from to a COM component - MIcrosoft Office Document Customization
Hey all,
I have attached two pictures of two different error I received below. These errors pop-up when I save power point 2007 and/or VISO 2007 documents as PDF.
I would be grateful for any suggestions that may help me fix this.
Thanks lots.
An error occured while PowerPoint was saving a file - Microsoft PowerPoint
Visio internal error :#3400 Action 2117: Publish as PDF or XPS - Microsoft Office VISIO
Microsoft Office 2010 is showing a security warning while opening a custom built office template in respect of Microsoft Word, Excel and Microsoft PowerPoint. This is really an awful security warning. However, it does not create other problems after click on Close. Have you any idea for the warning?
Please help.
Thanks in advance.
Security warning Macros have been disabled.
Security warning
