Hi fellow members. Is there a way for Outlook display countdown date? Does Outlook have this feature? I want a daily reminder or countdown until the specified date. I use Microsoft Outlook 2010 on Windows 7 64 bit. Any help would be much appreciated. Thanks in advance.
What can I do about my notebook its running outlook 2010 and after some time it just collapses and it shows no error at all. I had identical problems with my PC and I disabled outlook 2010 HP instant pim addin and can I disable it on my notebook too?
- 46 reads
- 1 comment
I have used like forever the same settings and for no reason yesterday when I tried to use my outlook I got this error message “pim sync network error”, I have asked some friends and they told me to try to disable outlook 2010 HP instant pim addin. Would that help me or what must be done to fix this?
- 29 reads
- 1 comment
Hi there. I just saved an Outlook PST file on a portable USB drive? When I open the PST file, I'm having an error of "unknown file". Am I doing something wrong while saving PST Outlook portable USB? I use Microsoft Outlook 2010. Thanks in advance.
- 59 reads
- 2 comments
Hi guys. Please help. I have a large pst file that I want to attach in an email. The problem is the file is too large. How do I resize pst files outlook? I use Microsoft Outlook 2010 on a Windows 7 64 bit system. Do I need a third party app for this?
- 71 reads
- 4 comments
I have an email in my Outlook that I think is corrupted. When I open the message, Outlook hangs and eventually crashes. I cannot open, move, delete this particular message. How do I remove corrupt email from Outlook? I use Microsoft Outlook 2003. Thanks.
- 59 reads
- 4 comments
Good Day TechyV!
Can anyone please tell me what is the Outlook Express Bulk Import Vcard Process? I need to know if there is a way to do a bulk import of Vcards in Outlook. Please help me anyone, I need guidance. I would appreciate any tutorial lessons and demo videos.
Thanks for your help.
Alyss Aellaa
- 65 reads
- 1 comment
Hello, Our office staffs are using Eudora for long time. Now we have to sift to Outlook for some reason. Do you have any outlook express 2007 tutorial by which we can trained up our colleagues?
Hello TechyV Friends!
I am looking for experts’ advices and suggestions on Synchpst for Outlook Professional. What are the benefits of using Synchpst? What are its strengths and weaknesses? Have you encountered any problems upon using Synchpst? Is it compatible to all platforms? Do you know any free application and software which is similar to Synchpst? If you have tried using Synchpst, then please help me and give me your suggestions and recommendations. I would be glad to hear your opinions.
Thank you so much.
- 60 reads
- 2 comments
Good Day Guys!
Do you think it is possible to synchronize Outlook with MySQL? If so, can anyone please tell me how it is done? Do you know any tutorial on how to synchronize outlook with MySQL? If not, can you suggests any tool or application which can help in the synchronization of outlook contacts in a MySQL database? Have you tried using a third party software? If yes then please share us your experiences, it will be very helpful to us.
Thanks in advance!
- 172 reads
- 3 comments
- « first
- ‹ previous
- next ›
