Display :
Did not find what you want,
Be the first to ask question on Internet
Category: Internet
I am getting an error "Securexam Remote Proctor Browser can't be opened because it is from an unidentified developer" on my Mac:
Category: Internet
I am a home user, I have installed Windows 7 64 bits on my computer. I have installed Adobe CS4 to my system. 5 days before I used this application, no issue detected. Now whenever I open this application, I am getting below error message.
Licensing for this product has stopped working.
This product has encountered a problem which requires you to restart your computer before it can be launched.
Error: 148:3
What should I do if I want to use the Photoshop application?
I cannot get in touch with Adobe technical support.
Category: Internet
Can someone help with this problem please? I am unable to start BitComet.
I have tried with reinstalling it but it didn't help. I uninstalled BitComet before reinstalling and that also didn't work either. Thanks in advance.
Bitconnect
Error occurs when initializing BitComet
Category: Internet
I am using a zandronum server, recently it’s started giving me this error. Please can you tell me the reasons for this error.
Zendronum cannot be opened because of a problem.
Category: Internet
I am using yahoo messenger from many days in my PC. From last couple of days it's not working. I have re-installed it, then I un-installed and installed it. But still the same. In the first dialog box after installation it says "the application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem".
Then it shows an error message "could not execute the external program "c:\..." ".
I have tried several times but every time it`s failing. I have installed it directly from the internet and even downloaded the backup file from a website. But it didn’t work.
Category: Internet
Whenever I open a PDF file following error occurs, and then the adobe reader restarts. I searched everywhere but I didn’t find any solution. What to do? Please help.
import setting
Import settings
An error occurred while importing settings. Import was not completed
Successfully, for more information about importing settings, click here.
The window will be closed automatically in 7 seconds.
Category: Internet
Dear Friends,
I am trying to add new friends in my yahoo messenger`s address book but I couldn’t do it properly. It`s saying that:
There was an error in the server while trying to add a contact. Please try again.
Please let me know what the problem is in my messenger?
messenger list
Category: Internet
Can someone help me please?
I have installed the latest version of Irfanview on my PC.
When I try to copy an image, I got an error message saying that
D:\My Documents\Pbits\obit2.bmp: Can’t read file header!
Unknown file format or file not found!
(For Unicode file names please activate the Unicode Plugin in ‘Properties->Language’)
I have checked the Plugin properties and it is checked to load when Irfanview starts up.
Am I missing something?
infanView
IrfanView
Category: Internet
What happens if someone sends a 2MB-sized attachment to more than 10 recipients, when, say a 20MB, limit for attachment has been set? Will it result in a delay in the delivery of the message?
Category: Internet
This is my problem: When I tried to run the Google Apps Migration for Microsoft Exchange tool to migrate email, calendars, and contacts for my users, on a 2003 Exchange Server, which is found in various time zones on a remote server (connections to the server is through RPC over a secure https (now I think it’s called Exchange Anywhere) and users are running either on Windows 7 with Outlook 2012 or Snow Leopard with Entourage 2008, on one of the accounts I got a message stating that the "Estimation failed for all users. Please check if the source server name (and authentication if applicable) and the list of specified users are valid. The log file contains numerous entries like the following:
