Display :
Did not find what you want,
Be the first to ask question on Internet
Category: Internet
Hi! Why do I have this problem that my files do not open properly when I download them from the internet through an email? I have the required software to open a specific file and it should open properly. But every time it shows an error. Is this some kind of security check or is there a problem with my computer/software?
Category: Internet
My internet explorer only works in safe mode. Is there any way to resolve the problem? Do you have any suggestions how can I solve his problem?
Category: Internet
Why my laptop won't connect to the internet? My laptop suddenly won't connect to wireless network. How can I fix this?
Category: Internet
I want to convert youtube videos into audio files. What program can be used to achieve this task and also can I be proposed one which undertakes batch works? Also, I want to know if the quality of the audio will be affected. Given that transcoding video into audio files pose any copy write issue?
Category: Internet
I was trying to connect my wii to the internet the other day and I was asked repeatedly for my MAC address. What is a MAC address? What is it used for other than the Wii? I noticed that MAC addresses are found on many devices such as mobile phones and tablets. Can anyone tell me why?
Category: Internet
Hi! I am working on a small project and making a website. I was trying to add variations in the website by using different font colors. I wanted a transparent color for my text as well but so far I couldn't find any code for transparent color on HTML or CSS. Is there any color code for transparent colors in HTML and CSS and is it possible to make text look possible?
Category: Internet
Except a few sites, my browser is always showing this error message. It wasn't happening before but recently I turned off the automatic Windows update because it was time consuming. I have noticed that this problem has started to occur after turning the windows update off. Is this some kind of a precaution, not to open certain websites? Is their a potential virus threat on these websites?
Category: Internet
What are the best days of the week to post content into your blog so that it reaches the maximum audience? Is there a preference for this? Is there a preferred time for this also? Can I post on weekends? Would weekend postings make my blogs less distinct as a lot of content gets posted on these days?
Category: Internet
What is Airport extreme and what is it used for?
Apple Airport extreme 2TB has Wifi i know that but why do people use it as it needs a DSL modem separately
