Hello, An oDesk Team application is downloaded and tried to install on my desktop. However, the program could not be installed and same error message of ‘Downloading failed’ appears every time. Below is the screenshot of error for your information.
Could any oDesk expert help me to install the application? Thank you very much.
- 65 reads
- 1 comment
I am looking for a good tutorial on an online address book. I want to learn how to use and customize it? I want to add an auto birthday greeting and some others. Please help me telling about creating new contacts and using the address book.
I keep on getting the following error message, whenever I try to scan a negative by using my Canoscan 3000F - I don't have the film guide for that scanner. I bought this second handed but could that be the problem?
ScanGear CS
Cannot scan for these reasons:
- The original may not be set correctly.
- The Film Adaptor Unit Protective Sheet may be put in place.
- The lamp may be not warmed up.
- 94 reads
- 1 comment
Hello. I really have nothing much to do at home until my brother came up to me and asked me a favor to do something for him. He mentioned about checking Google Page Rank. He said if I can search on how to check Google Page rank so I did. But to my dismay, I can't find any steps on how to do it so maybe you can help me with this. Thank you in advance guys!
- 60 reads
- 2 comments
Hello. I am currently using Windows mail to do transactions with friends and as I'm doing it all the time, it really eats up a lot of time inputting manually the email addresses over and over again. My friend mentioned about Auto BCC CC Windows Mail so I kind of thought of having this. But my problem is how will I get my Windows Mail automate the BCC and CC. Your help will highly be appreciated. Thanks!
- 66 reads
- 1 comment
I am a home user, I have installed Windows 7 64 bits on my computer. I have installed Adobe CS4 to my system. 5 days before I used this application, no issue detected. Now whenever I open this application, I am getting below error message.
Licensing for this product has stopped working.
This product has encountered a problem which requires you to restart your computer before it can be launched.
Error: 148:3
What should I do if I want to use the Photoshop application?
I cannot get in touch with Adobe technical support.
- 68 reads
- 1 comment
Can someone help with this problem please? I am unable to start BitComet.
I have tried with reinstalling it but it didn't help. I uninstalled BitComet before reinstalling and that also didn't work either. Thanks in advance.
Error occurs when initializing BitComet
- 81 reads
- 2 comments
I am using yahoo messenger from many days in my PC. From last couple of days it's not working. I have re-installed it, then I un-installed and installed it. But still the same. In the first dialog box after installation it says "the application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem".
Then it shows an error message "could not execute the external program "c:\..." ".
I have tried several times but every time it`s failing. I have installed it directly from the internet and even downloaded the backup file from a website. But it didn’t work.
- 104 reads
- 1 comment
