Display :
Did not find what you want,
Be the first to ask question on Hardware
Category: Hardware
I am trying to run the setup file for installing plugins I got this error:
"Can't install all files
Please check your destination directory for free space"
I am getting the same error even if I use the downloaded setup file or the zip version.
I have more than 71 GB free space on my hard disk.
I am getting the same error even if I download and install.
Please advice
cannot install files
Can’t install all files!
Please check your destination directory for free space!
Category: Hardware
How to Play Blue-ray Discs in Windows 7? I saw an error similar to this one in the breeding animal of Windows It comes up.
Windows Media Player cannot play the DVD.
Windows Media player
Windows Media Player cannot play the DVD. The disc was created in a manner that the player does not support.
I am the problem with this error message. They are there some suggestion to solve this, please help me soon...
Category: Hardware
Hi friends,
I am using Windows 7 64Bit as the operating system on my computer. I am using 3 USB Dongle. It was working perfectly but now I am facing problem with it. It suddenly stops working and lost all the signals. But after some time the signals automatically come back. I called to network support agent he directed me to uninstall and then re-install the dongle. I am looking for a way how to uninstall a 3 dongle safely. Your kind help is appreciated.
Category: Hardware
Hi everyone,
I am looking for different ways to automatically cd rom eject. I am doing an experiment and finding the ways to ejecting the CD ROM and stops the CD Rom from automatically ejecting. Can someone tell the different ways and options to eject the CD ROM? Have anyone tried this before?
Category: Hardware
I am bit confused with routers, please clarify. I am using a Comcast Internet service which is giving me a connection of 6mbps. 802.11b is 11mbps rate and 802.11g is 54mbps. If both standards are ALREADY faster than 6mbps why do people buy these faster routers? Isn't 802.11b more than enough?
Thanks for the help.
Category: Hardware
I need to check for hardware problems on my HP laptop. Is there any website from where I can download HP hardware diagnostic boot CD to do this? My laptop runs on Vista, I don't know much but maybe that helps.
Category: Hardware
Hello. I always receive an error when I try to uninstall ACE Mega CODEC pack program:
How I can uninstall this program? Please guide me.
Access violation error
CoDecS DashBoard
Access violation at 010005A0. Read of address 01264E31
Category: Hardware
Hello guys,
I recently bought a Nokia Smartphone after was disappointed by how fast the other phones discharge power. I thought the special characters for Nokia mobiles such as long lasting batteries and strong hardware would be maintained but that's not the case. Why can't smart phones hold power for long or why can’t they use stronger batteries for them?
Category: Hardware
I recently purchased a Toshiba laptop with windows Vista operating system. I want to watch Tv programs on my laptop. I purchased SSD-TV-813 USB2.0  TV tuner and installed it in my laptop. Then I tried to run it, but it shows that the driver is not installed.  I am searching for driver for laptop tv tuner. Please tell me how I can resolve my problem ? Is there problem due to hardware or software?
Category: Hardware
Techyv,
I have sony vaio update problem for the sound drivers. I recently tried to update my drivers but on completion, my speakers were not working. Can restore to default settings bring the sound back or there is another way through this.
Please help.
