Hello there,
Which is the best way to determine whether a cable used in a computer is a power cable or data cable.
- 135 reads
- 2 comments
I want to add an additional power cord. However, I do not know how to go about this. Can I get enough power codes from a power supply that I can buy, which can help me with my cause?
Thanks for the information.
- 157 reads
- 2 comments
I have a set of speakers that work on my iPod but not on my computer. They turn on but nothing happens. Is the problem with the computer or the speaker? How can these speakers work on my PC?
Thanks a lot.
- 115 reads
- 2 comments
Hallo there,
I want to use the CD drive on my computer but it cannot open. I proceeded to removing the driver from the add remove programs. However, the computer tells me it does not recognize the new hardware even after restarting it. What is the problem here and how do I fix such an issue?
- 110 reads
- 2 comments
What is the function of a switch that receives a frame that has a destination MAC address? However, the address is currently not in the MAC table. Who has an idea?
- 124 reads
- 1 comment
My case has both front panel audio and music. However, when I try to insert the headphone jack in front of the panel, it does not cut the audio from the main speakers. What could be the problem here?
- 132 reads
- 2 comments
