Recently I purchased a portable DVD player and today tried to update its firmware to latest version. Firmware easy home DEV portable player failed to update in the middle and I was hoping if someone knows the cause and how to rectify this problem? Any kind of help would be appreciated.
- 184 reads
- 1 comment
Can anybody suggest software that can help me in overclocking my machine's CPU/GPU/memory etc.? Preferably, it's one that I could use while on the OS environment, but I'm not sure if it can only be through BIOS mode?
I am also concerned with dust issues, and have been worried when one time while playing a game, my CPU's temperature went up to over 60°C. Other specs of my machine include an AMD processor (stock cooler) with MD/ATI graphics and GIGABYTE mobo.
My RAM is Kingston (value series, DDR2-800 CL6). Any help would be greatly appreciated. Thank you!
- 167 reads
- 1 comment
Hi , While using the android device , i get troublesome .It is not hoped by this device .
What can be done ?
Error message :
The process android.process,
acore has stopped
unexpectedly. Please try again.
Force close
- 196 reads
- 2 comments
I accidentally deleted hpqscnvw.exe oblivious to the fact that it’s an important file for my HP PSC All-in-One with Digital Imaging. Every time I open my PC or run other programs, I receive an HP application exception error “hpqscnvw.exe has generated errors and will be closed by Windows. You will need to restart the program. ”
This is now causing significant damage to my system. If it is the solution, how can I restore the .exe file?
Is it possible to clean damaged files if there are any?
- 403 reads
- 1 comment
AOL HD connected TV app has changed its name. With changing its name, what has it changed in it?
When is the changing form coming to us?
- 194 reads
- 2 comments
