Display :
Did not find what you want,
Be the first to ask question on Hardware
Category: Hardware
I have a problem with my internet. Browsing for solutions over the internet, someone mentioned a modem port scan. What does this have to do with my internet? I have my own internet but I think my neighbor is also connecting on my internet via wifi.
Category: Hardware
I would like to ask if a graphics card can be used with vista and can it fit in a PCI-E x 16 slot or supports pixel shader 2.0? Any useful suggestions?
Thanks a lot.
Category: Hardware
Hallo there,
What series of tests can be performed by the startup BIOS to determine whether it can communicate correctly with essential hardware components essential for a successful boot?
Thanks for the answer.
Category: Hardware
Hallo there,
I have one Ethernet cable from a router. I would like to slice it into two. Where can I get a double-port Ethernet in other works? I have no slightest clue.
Thanks a lot.
Category: Hardware
Hello there,
I want to know if the antc P180 case is compatible with the PC power and cooling turbo cool 1kw SR power supply.
Thanks for information.
Category: Hardware
Hello there,
I am trying to establish the term that I can use to describe the physical equipment of a computer system, for examples, the storage devices, keyboard and the screen. Who has any idea?
Thanks a lot.
Category: Hardware
Hallo,
There are two connections in my motherboard: a blue IDE connection and a black IDE connection. Which one can I use to set up a single drive?
Thanks
Category: Hardware
Hello there,
Which is the best way to determine whether a cable used in a computer is a power cable or data cable.
Category: Hardware
I want to add an additional power cord. However, I do not know how to go about this. Can I get enough power codes from a power supply that I can buy, which can help me with my cause?
Thanks for the information.
Category: Hardware
I have a set of speakers that work on my iPod but not on my computer. They turn on but nothing happens. Is the problem with the computer or the speaker? How can these speakers work on my PC?
Thanks a lot.
