Display :
Did not find what you want,
Be the first to ask question on Hardware
Category: Hardware
I have tried all of the basics - is there enough ink, is there enough paper, is the power turned on, and it just will not print. I see the print icon on my laptop but the jobs are just sitting there. What can I do? I have also tried turning my laptop off and on but no luck.
Category: Hardware
I use a USB frequently but my laptop often tells me there is an error and I should eject it. I'm afraid I will take it out and leave it somewhere, so I just leave it plugged in. Am I able to do this or am I causing harm by leaving it plugged in? Thanks.
Category: Hardware
The last laptop I had suffered a slew of battery issues. Mostly, the battery worn down immediately after only having it less than a year.  Is there anything I can do with my new laptop to ensure good health? Is the "constant charging will wear down your battery"? Truth or a myth? Thanks!
Category: Hardware
I have used the speakers on my laptop before and it has always worked fine, but now the speakers aren't working and I can't figure out what exactly to do. The sound is turned up, I can't see that anything is muted?  I'm not sure what to try to do to fix this other than restart and start back up but that doesn't work either. Help is appreciated. Thank you.
Category: Hardware
When I place my mouse into port 1, it works totally fine. It doesn't work at all in port 2. At first I thought it was the mouse, but then I put a flash drive into ports 1 and 2, and had the same result. Is there anything I can do to see if I can get that port working again? Or is it just done and I would have to get it repaired? Thank you!
Category: Hardware
Hello! I've been having issues with my mouse and my Microsoft laptop. I was discussing to a friend and they told me to re-sync the devices. I'm not sure exactly how to do this, so help is appreciated. I was going to just go and buy a new mouse and hope that fixed the issue but if this is an option I would like to try this first. Thank you.
Category: Hardware
What makes Nintendo Wii U game consoles different from Sony PlayStation 4 game consoles? In terms of model designs what do these two game consoles share in common? What do you like about the Nintendo Wii U game console that in your perspective can be inculcated into the designing of the next edition or generation of PlayStation say PlayStation 5?
Category: Hardware
My name is Donald; a 12 year old boy. I would wish to know the differences between Pentium Processing Devices and Celeron Processing Devices. What are some of the significant physical features they share in common? I would also like to know why the name Pentium and Celeron with respect to the different brands since they are all produce or made by Intel. Thank you.
Category: Hardware
Hello, my name is Jason and I happen to come across the word Transient Designers in a magazine after hearing a friend of mine used it in his speech on sound production. I have not had the opportunity to look really for the possible simplest but detailed meaning to the word “Transient Designer” and therefore would be happy to know what a Transient Designer is? And also to have the best guidelines that can one follow to use the Transient Designers in various mixes during an event such as a musical concert? Thank you.
Category: Hardware
I would need an assistance on the very use of the Universal Audio Compressor called 1176 compressor. I am privileged to have this awesome gadget as part of my set up for an upcoming musical event in my community and since after this event I may not perhaps have the privilege to use this gadget again for such an event, I therefore require a detailed and relevant settings as well as all the necessary explanatory info needed to help me use the 1176 compressor to its optimum. Thank you.
