Display :
Did not find what you want,
Be the first to ask question on Hardware
Category: Hardware
What are the distinct features of the iClever 6-Port USB travel wall charger? How is this gadget so special in terms of functions than other travel wall charger apart from it being used to charge multiple gadgets at a go? What are the safe measures to consider when using this gadget? What should be the average cost price of iClever 6-Port USB travel wall charger? Thank you.
Category: Hardware
What are the definitions of the following: virtual CPUs, virtual switches and virtual LANs? Is there a link between these two words in computing and what extent? Are there various types of virtual switches, and virtual CPUs? What are the characteristics of each type respectively? Philip is my name and a grade six student from South Africa.
Category: Hardware
Hello, I have been thinking of these few issues for a couple of weeks now and I would be glad if someone can help me by providing answers that would clear all my doubts. I would like to know if the use of the microwave does have a significant quality effect on the nutritional content of food. Are there any studies to prove a loss in nutrition due to the use of the microwave? And apart from what I do seek for, are there any other important information that even most people do not know of yet, causing a lot of havoc? Thank you.
Category: Hardware
What are your impressions and comments on the news that broke through the internet that a driverless car which was tried by the Swisscom which is a Swiss telephone company on the streets of Zurich last Tuesday? It is understood to be the first in its kind in the country however, was it worth venturing such project?
Category: Hardware
I would like to know what an electronic bidet toilet seat is. What are some of the vital features of the electronic bidet toilet seat? What is the concept hovering around the designing of the electronic bidet toilet seat? What are the reasons why the electronic bidet toilet seat be ascribed as a luxury that one cannot do away with? What should be the average price an electronic bidet toilet seat?
Category: Hardware
Hello, I am in search for a gamepad for Android Tablets and Phones which has a Bluetooth feature. Which brand of gamepad stands tall and also has excellent features? Is there another brand or even a better preferred gadget that can equally serve the same purpose and better? Thank you.
Category: Hardware
What are MicroTugs? What would make a tiny robot can pull up weights of objects known to be over a thousand times heavier than its weight? What would call for such technological development and what will make one go to such extend to think and create such staff? Philip Moore is my name. Thank you.
Category: Hardware
I have tried all of the basics - is there enough ink, is there enough paper, is the power turned on, and it just will not print. I see the print icon on my laptop but the jobs are just sitting there. What can I do? I have also tried turning my laptop off and on but no luck.
Category: Hardware
I use a USB frequently but my laptop often tells me there is an error and I should eject it. I'm afraid I will take it out and leave it somewhere, so I just leave it plugged in. Am I able to do this or am I causing harm by leaving it plugged in? Thanks.
Category: Hardware
The last laptop I had suffered a slew of battery issues. Mostly, the battery worn down immediately after only having it less than a year.  Is there anything I can do with my new laptop to ensure good health? Is the "constant charging will wear down your battery"? Truth or a myth? Thanks!
