Display :
Did not find what you want,
Be the first to ask question on Hardware
Category: Hardware
I am looking into getting an xdcam ex 35. I need one that offers high-end image capture,  increased control over depth of field, higher sensitivity in low light, lower image noise, and an exceptional dynamic range. What brand also complete compatibility with cine-style film lenses and consistency of vision for cinematographers used to shooting on 35mm film. Can you provide with with some idea as well as helpful details.
Category: Hardware
What is the best but affordable satellite TV in your PC that is available in the market today?
Something that can be easily set up and could provide the most number of channels worldwide.
There are some that are for free but are these real and not scams?
Category: Hardware
I am experiencing some lag Windows 7 HP wireless keyboard. You see, I am typing but what appears on my screen is that I am still typing. I do not think I have a problem with my PC because I just had it repaired and Window 7 installed. How can thus lag go?
Category: Hardware
I have a problem with my internet. Browsing for solutions over the internet, someone mentioned a modem port scan. What does this have to do with my internet? I have my own internet but I think my neighbor is also connecting on my internet via wifi.
Category: Hardware
I would like to ask if a graphics card can be used with vista and can it fit in a PCI-E x 16 slot or supports pixel shader 2.0? Any useful suggestions?
Thanks a lot.
Category: Hardware
Hallo there,
What series of tests can be performed by the startup BIOS to determine whether it can communicate correctly with essential hardware components essential for a successful boot?
Thanks for the answer.
Category: Hardware
Hallo there,
I have one Ethernet cable from a router. I would like to slice it into two.
Where can I get a double-port Ethernet in other works?
I have no slightest clue.
Thanks a lot.
Category: Hardware
Hello there,
I want to know if the antc P180 case is compatible with the PC power and cooling turbo cool 1kw SR power supply.
Thanks for information.
Category: Hardware
Hello there,
I am trying to establish the term that I can use to describe the physical equipment of a computer system, for examples, the storage devices, keyboard and the screen. Who has any idea?
Thanks a lot.
Category: Hardware
Hallo,
There are two connections in my motherboard: a blue IDE connection and a black IDE connection. Which one can I use to set up a single drive?
Thanks
