Display :
Did not find what you want,
Be the first to ask question on Hardware
Category: Hardware
I bought a new hard drive since the previous one technically failed. But I can’t use it yet because I don’t have my leopard disk. My files are on my backup drive through Time Machine. Since I still have my backup files, can I install OSX using that backup drive?
Category: Hardware
I just installed my Silverlight 4.0 separately to my Visual Studio 2008. However, after installing the version, I can’t find the option button on my project type Visual Studio. Did I miss something while installing the Silverlight application? Can you help me find it?
Category: Hardware
Hello!
I am planning to erase the values just by clicking xaml, when a button popup, click the button to open it. Then by clicking on xaml button, there will be no values anymore in the popup window. Is this possible? I need your suggestions here guys.
Please help.
Category: Hardware
I have a HP Pavillion a1657c computer with WD2500JS-60NCB1 driver and A8M2N-LA motherboard which keeps recycling to start up but won't open. I was doing a disk check because dfrag wouldn't work and it stated some files could not be accessed and I must restart.
Category: Hardware
Without rebooting the computer, can I remove a ghost out of proc which started running in my computer after I deleted a guest directory without shutting down?
Category: Hardware
I heard that if my processer going too much hot it can be damaged but I need to know how much hot it is? How to know that?
Category: Hardware
I want to increase the memory of my computer, but it does not detect all new memory.
Category: Hardware
      I have a cannon ip2772 printer. Some times it cannot work properly and I cannot get a good print.
Category: Hardware
       Some times when I want to start my computer it says that file missing or corrupt. what can I do?
Category: Hardware
There is a un excepted noise comes from my computer, what can I do for the problem
