Display :
Did not find what you want,
Be the first to ask question on Hardware
Category: Hardware
I made a simple slideshow presentation using my Archos 7 Home Tablet. However, whenever I move on to the next slide, I had to swipe the screen rather than press a simple button. I find it inconvenient. The same is true when I made a PowerPoint macro enabled slideshow presentation. Again, I had to swipe rather than press a button. I need your help on how to customize slideshow buttons for easier access to my slides. Thank you very much.
Category: Hardware
I’m having a problem of removing the single retaining clip from the heatsink from my computer which runs through the centre of the unit. I already tried to remove it using a screwdriver while pushing and pulling it down but still the single clip couldn’t release. And my last choice is I want to remove my motherboard but if I do that, I'll probably have to but a new heatsink unit complete with a retaining clip.
I need your advices and suggestions about this. So that I could install my Athlon XP 2400 just to upgrade an older motherboard with a Socket of 462.
Category: Hardware
How will you know if Node 1 has failed to work and few resources, like Disk and SQL, were not transferred from Node 1 to Node 2? Thanks in advance!
Category: Hardware
Hi All, Can we clone production ERP boxes with the configuration and drives? Regards Chandra
Category: Hardware
While trying to set up ancient video games like Dave I received this problem: "D:\FLASHG~1\DAVE.exe The NTVD CPU has encountered an illegal instruction. CS:c000 IP:5b9a OP:0f 00 00 00 03 Choose ‘Close’ to terminate the application." I can't start my .bat C++ gathered applications; as I attempt to press on the .bat, it posted a dark-colored CMD screen and runs. I have scanned my PC using ESET antivirus 4 and Malware bytes but no threats have been found. I am running Windows XP.
16-bit MS-Dos Subsystem
Please help me.
Category: Hardware
How do you put a dstname field into the syslog in Sonicwall Pro 3040? I want this field to contain the URL input by the user for tracking.
Category: Hardware
I have a Windows 2003 server and iSCSI target server both in the same host.
Does the traffic in iSCSI between VMWare users stay within or does it go somewhere and then go back in?
Category: Hardware
One of my clients has an issue using a particular USB disk drive for backing up. He is receiving the error “Error-105 unexpected end of data.” on Retrospect Multi Server version 7.6.123. I have tried re-cataloging but failed. I did chkdsk /r which completed successfully. But on starting Retrospect again, it failed. Why is it caused using on this USB? How can I get this solved?
Category: Hardware
Backing up a 1.6TB Workspace to 3 LTO4 tapes using a Tandberg TS400 Robotic was successfully completed. However during the verification process, I received an Error 102 which is a connection issue I guess. This is caused due to the failure of our RAID drives during the process. I would like to know whether it is possible to verify a particular tape in a multi-tape backup.
Category: Hardware
I was getting message that my hard disk is corrupted. So I bought a new Hitachi hard disk and change the old one. When I am trying to connect the old hard disk through a USB port, it was not detected by the computer. My personal files which are very important is in the old hard disk and I need to recover it. Please guide me to get those files as I don’t want to give the disk outside. Please help me to get out of this problem. I will thankful for all help.
