When I installed Roxio Creator 2012, many errors appeared. I tried to reinstall the program several times but same error message appeared repeatedly.
- 1168 reads
- 3 comments
I will be using Cisco WebEx Video Conferencing on T1. I want to know how many bandwidth it requires when using a DSL. How many T1 is required to run this? Any help will do. Thank you.
- 382 reads
- 1 comment
Is it possible to have an APC UPS management tool or with Network Ups Tool (NUT) to connect to a server through cables or USB and notify other computer on the network and shut down their devices? What are the possible issues when performing this setup?
- 468 reads
- 2 comments
I purchased a new computer with Windows 7 installed on it. Recently, I hooked my device with a wireless Photosmart Premium Fax 309 series and it worked perfectly fine. However, this is not the case when I installed it on my laptop with Windows XP Professional. I do not know what went wrong because it is running well with Windows XP before. Whenever I am trying to install the program, this message appears, “Fatal error MSI netdevice manager01” and the only thing that I modified on my device is a new router as I joined BT Infinity almost a month ago. Can somebody help me please? Thank you!
- 300 reads
- 1 comment
I have a Windows XP computer system and recently, I opted to uninstall Kodak Easy Share and Kodak updater program using add/remove program feature in Control Panel. However every time my computer starts up this message pops up, “Runner Filename (Kodak Software updater.exe) lacks a (the app id separator)”. I really do not have an idea to resolve this issue.
- 365 reads
- 3 comments
I want to restrict my user in using only two folders in a certain drive. For example, I just want him to have an access in drive D where there will is only 2 folders; 1 FINAL and 1 WIP. I want to add some restriction on these two folders especially the Final folder.
I also want the following to happen:
a) The user should not have any permission or control in deleting the folder.
b) One problem is he could not overwrite the file. Every time he would try saving the file in Final folder, he could save it initially but if he will modify it he could not save it with the same filename anymore.
Can someone please help me ASAP with this thing? Thanks!
- 247 reads
- 3 comments
I am looking for help to fix an Internal Error 2755.3. This started when trying to install the Sperry application add-in, an error message is coming which says ‘Internal Error 2755.3’ and an error ‘pathname/mapped drive not found’. Please help me to solve this issue. Thanks in advance.
- 393 reads
- 2 comments
Hi Guys,
Please help me find solutions to speed up my internet connection. As of this time, i am experiencing slowness in my internet connection.
Hope you can help me solve my problem.
- 274 reads
- 2 comments
Nowadays I faces a big problem to use broadband connection. Sometimes it is become so fast and sometimes it becomes so slow do not know why it occurs.
Again when I use modem or another system there also better to use. What is better in this modern age?
- 283 reads
- 3 comments
When I turn on mycomputer, the fans spin for just an instant, and the front panel LED and the LED on the main board remain lit, but the unit won't turn on. It had been running fine one night, and the next day it was like this. I replaced the small battery on the main board but that didn't help. Could it be the power supply?
- 483 reads
- 2 comments
