Display :
Did not find what you want,
Be the first to ask question on Hardware
Category: Hardware
Hello everyone, each time I try to download some data from the internet I am told my megabyte space is insufficient. How do I solve this memory issue? Is there a way I can create the needed space on the computer I currently use? I am in need of advice here, thanks.
Category: Hardware
Hello, I would like to buy some computer hardware and software. Is there anything I should know beforehand? What are the technological, organizational or management issues I should consider. Thank you.
Category: Hardware
Hi everyone, who has an idea on how I can use the normal H Bridge FET, switches for my battery charger and inverter application. I want to use the two in a sine wave offline UPS. The machine I am currently using is a PIC16F72 micro controller. How do I go about this? Thanks for the answer.
Category: Hardware
Hello there,
I disconnect my USB in the wrong way and now my pen drive is spoilt. I would like to know how can i return things to normal once more. The windows I use do not recognize my damaged pen drive.
The pen drive has two USB slots. Thanks for your answer.
Category: Hardware
Hi experts,
I am trying to start my computer server but nothing comes up on the screen. I keep on getting messages such as system failure, memory test, and such. What could be the problem and how do I fix it? I am not good with computers.
Thanks a lot for your help.
Category: Hardware
What is the use of watts when powering machines like computers? I ask this because I want to power a Hercules 9800XT and an Asus A7N8X-EAMD XP2700. Can 300W do? Any answer?
Thank you.
Category: Hardware
I recently acquired a Samsung Galaxy Ace and I want many features in it. Does anyone know where to buy a new Flash Lite 4 for Galaxy Ace?
Category: Hardware
Hi everyone,
I would like to make use of a 24-gauge line cord to attach to my DSL modem. The distance to be covered is about fifteen feet from the wall socket to the modem. Is this link better than the common phone line cord? Moreover, will it work at a faster rate?
Thanks for any helpful information.
Category: Hardware
Hi
I have a bits tone generator at my workplace. The model is blits ATG202. I do not know anything about this equipment and how to use it. I ant to know how can I use this and what are the basic configurations of this.
Thank you
Category: Hardware
Hi guys,
My camera has encountered a problem on my PC. However, the same camera is working well with other PC. Have a look at the screenshot below. What does it mean? I have no idea for the error.
Error -1074360293 ocurred at IMAQdx Get Image.vi
Error -1074360293 occurred at IMAQdx Get Image.vi
Possible reason(s):
NI-IMAQdx: (Hex 0xBFF6901B) Timeout
How can I get a remedy of this issue? Please help.
Thanks in advance.
