I am trying to copy a DVD movie from a MDS/MDF source file. The size of the movie is 7.4GB and I used a DVD Rewritable disk when burning. When I inserted the disk and started the burning process, I heard a loud noise and after that it shows the error below. The error code is 0x052102. How can I fix this?
CDBurnerXP
(devInvalidAddressForWrite) Could not write to Disc (LBA: 32 Length: 32).
Invalid Address For Write. -0x052102
- 677 reads
- 1 comment
Can someone please explain to me what it means when a blue screen appears with an error message saying: “FILE NAME: USBD (01) + 00094F ERROR: OE: 0028: FF09D22F.” I got this error message when I connected my brand new Onyx Portable Media Player 4GB at the back USB port of my computer. I have tried hitting the back button and it makes my computer work normally but it does not install my MP3 player. The manual says it will automatically appear in My Computer but I could not find the Drive for my Portable Media Player. I found it in the Device Manager hard disk controller but it has a red error on it although it says that the device is working properly when I checked its properties. How can I use it when I can even find an icon to run it?
- 531 reads
- 1 comment
I am having trouble with my Blu-ray player since the other day. It was having memory problem and it needs to restart. Some other error problems that were shown on the TV screen were telling me about software update. It says that the “Orb BR software requires update. Orb BR will update and restart in 5 seconds, please wait.” but it did not update anything in it. Besides I have the latest version of the software installed. So why do it prompts me to update? I’m confused about this. Can anyone tell me whether there is already a new version of software launched? Do I need to install it if there is any?
- 231 reads
- 2 comments
I cannot sync my Cortex Controller and Microprocessor. I tried every possible solutions but I am unlucky to perform it correctly. The VEXnet Joystick and Cortex Microcontroller have a full battery charged and I successfully connect it through the USB cord. The green lights of VEXnet are active. How can I sync the two? Please help.
- 239 reads
- 1 comment
I have purchased a Cherry GmBH Fingerprint Scanner, Smart Card Reading Keyboard. But the installation CD does not contain the option to install with Windows Vista and Windows 7.
I have tried with the installation CD, but there was no use. Only the keyboard is working properly and the scanner is not working.
The installation ended with an error message which says that ‘Update driver error’. I have tried by updating all drivers, but there was no change in the result.
When I am trying to register the fingerprint it also gives an error which says that ‘Scanner is not able to open’. I have searched in the forums but nothing found useful. Please help me to solve this problem. I will thankful for all help and support.
- 282 reads
- 1 comment
I am burning movies from the hard disk to a freecom device by using the Deepburner free package and the version is 1.9.0.228. it was working properly for more than six months.
But suddenly I’m getting an error message which displays that ‘Drive may be busy, not ready or empty’. After that I am using Verbatim DVD-R disks and the basic burnings are doing properly. I thought it is the problem with the hard disk and changed the hard disk. But the error still comes up.
I have also tried by changing the writing speed to very low, but there was no change in the result.
Please help me to fix the problem.
Thanks in advance.
- 204 reads
- 1 comment
HI! my computer has problem in installing drivers. when i insert a flash disk or a modem installs automatically then in the process displays insert a window XP professional service pack 2 CD and i do not have the CD. How i can i solve this, please help.
- 330 reads
- 3 comments
Different Types of Floppy Diskettes
Can anyone help me understand
thanks in advance
- 570 reads
- 3 comments
Hello. I would just like to ask about my headphone jack in my new ThinkPad Edge E520. It has only one jack which is very unusual to me. I usually notice two jacks in most devices like this, one for the microphone and one for the earpiece I suppose. What I have in my mind is that maybe this jack has a dual function for both microphone and earphone. But I am having a 2-jack headset here. Can I still use this? Will it damage my device if I try plugging it there? I think I can use wireless headset but I prefer to use the wired one. Or is there some sort of adapter I could use? I don’t want to try plugging my headset because I’m afraid it could damage the jack. Any suggestions?
- 789 reads
- 3 comments
