Display :
Did not find what you want,
Be the first to ask question on Hardware
Category: Hardware
Hello IT experts,
I am trying to run the application “Collaborate” but Revit is resisting to run this external application. I was looking for a solution then I heard about you experts and hope to resolve this error. It would be really appreciated for your assistance in this problem. Looking forward to hearing from you.
External Tools – External Tool Failure
Category: Hardware
What is the purpose of the language PL/SQL? What are its advantages over SQL Query Language? Where is it used?
Category: Hardware
What is 64-Bit computing? What are its advantages? Is it different for MAC and Windows or is it the same for both?
Category: Hardware
What are cores in CPUs? What do the numbers in the names of the cores represent? Are core and processors the same?
Category: Hardware
In the recent times, there has been a development in electronic devices. A memristor has been invented. What is a memristor? What are its features? Is it capable of replacing any component of the computer processor?
Category: Hardware
What is the use of a Database Management System and what are the advantages of DBMS over the File System? Also, state the drawbacks of a File System.
Category: Hardware
In what way can we protect against DOS attacks? What are the different ways? Also can we prevent such attacks? If yes, then how can we achieve it?
Category: Hardware
What do you mean by a DENIAL OF SERVICE (DOS) attack? What does it do? Does it harm the computer or is it also a type of attack to steal a user’s identity?
Category: Hardware
There are processors of various sizes available. What is the use of a processor with a bigger size? Does it have any advantages? (Compare a 32-bit and 64-bit processor)
Category: Hardware
Processors are fixed/placed into various devices like phones, laptops, computers, etc. What are such processors called? What are the characteristics considered to design them?
