Hello guys,
All about converting avi to DVD sync. Some avi format file is not supported by any other media player so I decided to convert it to DVD. Can you tell me how will I going to do it? To merge it all in only one DVD package so that there will be no hassle at all, suggestions and ideas will probably help alot.
Thank you.
- 227 reads
- 2 comments
Hey people,
I am looking to buy a new android cell phone in october 2012. I am looking for phones under rs.20000 with minimum 1ghz proccessor and good ram. also i would prefer a phone which has better develepoment support for custom roms etc. atleast give me 5 options.
- 496 reads
- 3 comments
Whenever I inserted any removable disk on my PC, I could not open it. Windows is always telling me to format it but when trying to format, an error occurred stating that “Windows is unable to format disk”. How can I format without getting this error message? Is there any other way that I can format aside from clicking on the My Computer folder and right-click it to format?
Please send me some advices.
- 363 reads
- 2 comments
Hi! I have an Asus Transformer EEE Pad and I am trying to connect it to my TV via HDMI but it always say Invalid Format. It won’t work with my other TV as well. But it used to work on both TV before. I have tried several resolutions and picture settings to no luck. What can I do?
- 246 reads
- 1 comment
Good day to all experts! Can you suggest for websites or links that can show me the ways using Delphi print a file to a usb? thank you!
- 188 reads
- 2 comments
What are hardware upgrades ?
What is computer hardware and hardware upgrade
Thanks in advance
Regards
- 172 reads
- 4 comments
I use a hp laptop. I heard about the term base system device stone but do not know much about it. Can anyone tell me how can I detect the base system device stone of my laptop? Any sort of suggestions about it please.
- 196 reads
- 2 comments
Hi Experts,
I am having nsis software on my desktop.I need to access the nsis control.I tried it on windows control panel.But could not access it.Advice me on nsis console output.Thanks.
Aimeemorgann
- 356 reads
- 2 comments
