Hallo there,
What series of tests can be performed by the startup BIOS to determine whether it can communicate correctly with essential hardware components essential for a successful boot?
Thanks for the answer.
- 106 reads
- 2 comments
Hello there,
I want to know if the antc P180 case is compatible with the PC power and cooling turbo cool 1kw SR power supply.
Thanks for information.
- 133 reads
- 2 comments
Hello there,
I am trying to establish the term that I can use to describe the physical equipment of a computer system, for examples, the storage devices, keyboard and the screen. Who has any idea?
Thanks a lot.
- 111 reads
- 2 comments
Hello there,
Which is the best way to determine whether a cable used in a computer is a power cable or data cable.
- 122 reads
- 2 comments
I want to add an additional power cord. However, I do not know how to go about this. Can I get enough power codes from a power supply that I can buy, which can help me with my cause?
Thanks for the information.
- 137 reads
- 2 comments
I have a set of speakers that work on my iPod but not on my computer. They turn on but nothing happens. Is the problem with the computer or the speaker? How can these speakers work on my PC?
Thanks a lot.
- 101 reads
- 2 comments
