Display :
Did not find what you want,
Be the first to ask question on Hardware
Category: Hardware
Hello there,
Which is the best way to determine whether a cable used in a computer is a power cable or data cable.
Category: Hardware
I want to add an additional power cord. However, I do not know how to go about this. Can I get enough power codes from a power supply that I can buy, which can help me with my cause?
Thanks for the information.
Category: Hardware
I have a set of speakers that work on my iPod but not on my computer. They turn on but nothing happens. Is the problem with the computer or the speaker? How can these speakers work on my PC?
Thanks a lot.
Category: Hardware
Hi everyone,
How many types of slots are there in a conventional PCI? Moreover, how many possible PCI card configurations can use such slots?
Thanks for your help.
Category: Hardware
Hallo there,
I want to use the CD drive on my computer but it cannot open. I proceeded to removing the driver from the add remove programs. However, the computer tells me it does not recognize the new hardware even after restarting it. What is the problem here and how do I fix such an issue?
Category: Hardware
Hello there,
My 2001 HP pavilion service pack keeps on telling me that I do not have a high-speed UDB controller 2.0 tech. What is the problem here? It tells me to re-configure, but I do not know how? I would appreciate your help.
Category: Hardware
What is the function of a switch that receives a frame that has a destination MAC address? However, the address is currently not in the MAC table. Who has an idea?
Category: Hardware
Hallo,
I want the most excellent output method that can help me work with a handheld computer color photograph, memorandum, resume, a company annual report, as well as a statistical report. Any idea is welcome,
Category: Hardware
My case has both front panel audio and music. However, when I try to insert the headphone jack in front of the panel, it does not cut the audio from the main speakers. What could be the problem here?
Category: Hardware
Hi, my computer has a rapid USB host controller. However, when I try inserting a USB 2.0 device it tells me that it plugs into a non speedy USB host controller. What is the main issue with the USB host controller? Thanks.
