I want to add an additional power cord. However, I do not know how to go about this. Can I get enough power codes from a power supply that I can buy, which can help me with my cause?
Thanks for the information.
- 147 reads
- 2 comments
I have a set of speakers that work on my iPod but not on my computer. They turn on but nothing happens. Is the problem with the computer or the speaker? How can these speakers work on my PC?
Thanks a lot.
- 102 reads
- 2 comments
Hallo there,
I want to use the CD drive on my computer but it cannot open. I proceeded to removing the driver from the add remove programs. However, the computer tells me it does not recognize the new hardware even after restarting it. What is the problem here and how do I fix such an issue?
- 103 reads
- 2 comments
What is the function of a switch that receives a frame that has a destination MAC address? However, the address is currently not in the MAC table. Who has an idea?
- 116 reads
- 1 comment
My case has both front panel audio and music. However, when I try to insert the headphone jack in front of the panel, it does not cut the audio from the main speakers. What could be the problem here?
- 127 reads
- 2 comments
Hi, each time I start my computer, a message that say there is no signal input appears. It then goes o to hang for approximately ten to twenty minutes before booting. This has been going on for some time. What is the problem here?
- 108 reads
- 2 comments
