Display :
Did not find what you want,
Be the first to ask question on Hardware
Category: Hardware
I am exercising virtual disk manager and attempting to amend a virtual hardisk. After that I received an error while applying drive amendments. How can solve this issue?
Error Applying Drive Changes
Category: Hardware
An error message appears (as shown in the screenshot) for the assembly when I did run my work in Solidwork simulation while simulating of transferring of heat. I don’t understand actually what shall I do now. Can you please help me?
Heat Transfer
Heat Transfer
Incompatible initial temperatures
Category: Hardware
Today I restarted my computer because of some repairing issues. But it was surprising for me that after starting the computer an error message window occurred suddenly which you can see in the below attached image. Please help me to resolve this and also let me know why this occurred?
could not be loaded
HP Product Detection
AClmControl.exe - .NET Framework Intialization Error
Category: Hardware
I am trying to install X11 but not able to install this because of the following error message:
New Software already exists on your computer
Problem: You cannot install X11 on this volume. New Software already exists on your computer.
Category: Hardware
In my computer Target Microcontroller is not responding. I don’t understand why this message is occurring over here? Does anybody know about its solution? Please help me regarding this issue I am frustrated
he adapter and the target microcontroller.
Error
Target Microcontroller is not responding!!!
Please check the connection between the adapter and the target microcontroller.
Category: Hardware
Hi!
I have downloaded the driver from the ASUS [company server] and open the Driver-Disk-AHCI-Win7-x64 from the sub folder of main folder, and run/double click the amd_sata windows installer. The process gets started but it stopped when an error faced by me.
[An error screen shot is here]
AMD Catalyst Install Manager
An unknown error has occurred.
Please exit and restart Catalyst Install Manager.
I have just one option in error message i.e. ‘OK’ I don’t understand how it can be handled. Please tell me about this anomaly as soon as possible.
Thanks in advance.
Category: Hardware
Hi there,
There is a problem when I try to register a second Host Bus Adapter HBA with one host. Then I examine the current link status of Connectivity Link Status tab and find that the second HBA does not appear. Consequently I register the HBA with ‘Create.... ’ again.
However, an error message appears in the Create Initiator dialog and please finds the following screenshot for your reference.
Does anyone have idea the procedure of registering HBA and any method for the removal of any unregistered dead entry?
Thanks in advance.
Category: Hardware
Hi Friends,
A couple of days ago I bought a fresh computer with windows 7 64 bit. With it I got a UPS. Later then, I adjust the hardware and attempted to install the software. Unexpectedly Installation aborted and I got an error message which you can see in the below attached image.
Does anybody get this type of error before? I need assistance regarding the installation.
Problem: Repeatedly running there is an instance of setup running.
Please exit.
Category: Hardware
I was using Basic x64 and TMPGEnc Authoring Works, It was worked flawless for me until now. After I set up my options in "Output" which included having the writer settings at maximum level, when I click start, it runs for a few seconds then I will get an error message that says "Unsupported file (error code 0x80040003)"
Media source type selection
TMPGEnc MPEG Edition2.0
Category: Hardware
I am having a problem while trying to create a DVD with TMPGENC DVD AUTHOR 4.
When I try to start creating a DVD. The output what I will get is an error bar saying that:
An error occurred while canceling the title copy to the hard disc drive. Please refer to the details below. The device is not ready (Error code0x80070015)
What does this mean? I have never come across this problem until today.
TMPGEnc Authoring Works 4
