Hallo there,
I want to use the CD drive on my computer but it cannot open. I proceeded to removing the driver from the add remove programs. However, the computer tells me it does not recognize the new hardware even after restarting it. What is the problem here and how do I fix such an issue?
- 101 reads
- 2 comments
What is the function of a switch that receives a frame that has a destination MAC address? However, the address is currently not in the MAC table. Who has an idea?
- 115 reads
- 1 comment
My case has both front panel audio and music. However, when I try to insert the headphone jack in front of the panel, it does not cut the audio from the main speakers. What could be the problem here?
- 124 reads
- 2 comments
Hi, each time I start my computer, a message that say there is no signal input appears. It then goes o to hang for approximately ten to twenty minutes before booting. This has been going on for some time. What is the problem here?
- 107 reads
- 2 comments
Hello, I would like to buy some computer hardware and software. Is there anything I should know beforehand? What are the technological, organizational or management issues I should consider. Thank you.
- 132 reads
- 2 comments
