Hi guys,
My camera has encountered a problem on my PC. However, the same camera is working well with other PC. Have a look at the screenshot below. What does it mean? I have no idea for the error.
Error -1074360293 occurred at IMAQdx Get Image.vi
Possible reason(s):
NI-IMAQdx: (Hex 0xBFF6901B) Timeout
How can I get a remedy of this issue? Please help.
Thanks in advance.
- 219 reads
- 1 comment
Hi everyone,
I'm facing an issue by the time when I wish to use internet via PPPoE connection. It results me with the subsequent error message saying,
Error 651: The Modem (or other connecting device) has reported an error.
Error Connecting an error
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
- 600 reads
- 1 comment
Hi
I get an usb foot pedal as a present from my uncle. I heard that it can use for many kind of innovating things. I also heard about the usb foot pedal sdk. What are the things that we can do with this SDK?
Thank you
- 169 reads
- 2 comments
Hi
I have damaged 8 GB micro SD card. Some times it identifies the matching but cannot open the SD card. There are lots of important data inside this SD card. Is there software that can explore the SD card and repair it?
- 184 reads
- 3 comments
Hi Experts,
My HP Pavilion dv7-6b40ew hard disk, capacity 640 GB has encountered a problem. I want to make partition of my hard disk and for these reason I installed EASEUS Partition Master. However, while making a new partition I received an error message as under.
I visited several sites but no result. Have you any idea for the issue? How can I make several partition of my hard disk?
Please help.
Warning
Please convert an existed primary partition to logical partition, and try again.
- 1008 reads
- 1 comment
The problem is with my camcorder Canon FX100. I received a warning message while editing a project from it using the CF card for the test footage. Have a look at the screenshot below. How can I get a remedy of this issue?
Please help.
Warning
“CLIPS001 folder” contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media.
- 322 reads
- 2 comments
The problem is with my AMD AVT drivers. I installed it successfully and found no exceptional message while installing. However, during start up I received an error message. The screenshot of the error message is as under.
Have you any idea for the error message?
Please help.
C:\Program Files\AMD AVT\bin\kdbsync.exe
Windows cannot find ‘C:\Program Files\AMD AVT\bin\kdbsync.exe’. Make sure you typed the name correctly, and the try again.
- 729 reads
- 1 comment
I received an error message while overdriving AMD Phenom Processor with MSI Motherboard. It cannot detect AMD CPU on the computer. I tried several ways to get it ok but failed. If you have any idea for the error message, please help.
Thanks in advance.
AMD OverDrive
AOD cannot detect AMD CPU on this computer.
- 1697 reads
- 2 comments
Hi guys,
The problem is with my SLI cards. I have configured my machine by dual GTX-555s in SLI and received an error message. The screenshot of the error message is as under. Have you any idea for the error message? Please help.
Thanks in advance.
On client “local” 127.0.0.1:36330: GPU 0 not found
- 171 reads
- 1 comment
The problem is with the Sapphire AtiRadeon 5770 graphics processor set up. I received an critical error message during set up the same with the newest drivers on my machine running with Win 7 64-bit, Phenom II X4 965 Black Edition and 4GB of RAM. I do not find any reason behind the issue.
Have you any idea? Please help.
Thanks in advance.
General protection fault!
History:
Stack:
Address=0x10c59b75 (filename not found)
Address=0x10c6d81b (filename not found)
Address=0x10c84e53 (filename not found)
- 154 reads
- 1 comment
