Display :
Did not find what you want,
Be the first to ask question on Hardware
Category: Hardware
When installing windows on a system the setup produces error: “Windows cannot be installed to this disk. The selected disk is not of the GPT partition style?”
Category: Hardware
I have installed Microsoft OneDrive on my Windows Operating System but an error message shows up trying to access this application. How can I fix this issue? I really need suggestions to demolish the problem. Thanks for your cooperation.
Microsoft OneDrive
We couldn’t access
C:/Users/Michael/OneDrive/Pictures
Please make sure this file or folder still exists in this location and restart OneDrive, or click “Reconfigure OneDrive” to set up your OneDrive folder again.
Category: Hardware
I have installed Adobe Captivate on my Windows 7 Operating System but an error shows up trying to capture a high density display. I have attached an error image so please help me resolving this problem as soon as possible. Your cooperation would be really appreciated.
Adobe Captivate
Capture is disallowed since High-density display was detected. Please set ‘DpiAwareness = 1’in AdobeCaptivate.ini and restart the application.
Category: Hardware
Hi experts,
I am having a problem on startup of adobe premiere pro saying “Adobe Premiere Pro could not find any capable video play modules. Please update your video display drivers and start again”. I really need to fix this issue as soon as possible. Please share some positive response.
Category: Hardware
Hi everyone,
I have installed Microsoft Office Word and got an error message trying to open XML file. I really tried to demolish this error but couldn’t get any success. How can I fix this issue? Your help would be really appreciated. Thanks for your cooperation.
The Open XML file Archive.dotx cannot be opened because there are problems with the contents or the file name might contain invalid characters (for example, V).
Details
The file is corrupt and cannot be opened.
Category: Hardware
Hi experts,
I am using Mac Operating System and have installed Adobe InDesign but an error occurred trying to open a file “Cannot open the file”. How can I fix this error message? I need your cooperation to fix this problem so give me some suitable tips. Thanks for your cooperation.
“Monitoren_Content_week21_2009.indd”. Adobe InDesign may not support the file format, a plug-in that supports the file format may be missing, or the file may be open in another application.
Category: Hardware
Hi Experts,
I have installed Adobe Photoshop CC 2015 on my Windows 10 Operating System but I got an error message preparing a graphics project. I tried hard to demolish this problem but couldn’t get any success. How can I fix this issue? I hope you may help in better ways. Thanks for your cooperation.
Due to a problem initializing CC Libraries, existing links to library graphics will appear broken and new link creation will fail.
Category: Hardware
I am using Windows 7 Operating System and have installed Microsoft Excel 2016. It was working perfect but today an error has occurred using excel. I want to remove this error and need your assistance. Thanks for your help.
Excel Services
We don’t know what happened, but something went wrong.
Could you please try again?
Error id: 2170479d-7843-10ce-b1f1-08e01fe7e838, 20151202143435
Category: Hardware
An error occurred during local report processing saying the number of rows exceeds the maximum possible rows per sheet. I don’t know how to fix this problem although I have a small excel sheet. Let me know the procedure to demolish this error. Thanks!
Export Error
An error occurred during local report processing.
Excel Rendering Extension: Number of rows exceeds the maximum possible rows per sheet in this format; Rows Requested: 121320, Max Rows: 65536
Category: Hardware
Recently I tried to install an application useful for editing but it says “Application installation not started. I have tried enough to resolve the error as mentioned but I think experts can provide me better help and instructions. Thank you for your help.
Application Installation
The application could not be installed. The most common reaction is that software does not support the version of Windows currently installed on your computer. You can try starting the application installation from Application catalog again.
