Display :
Category: LCD & Plasma
Hi, I just found about dead pixels on the LCD monitors and I am very much curious to know a bit detailed on it. In addition, is there a way to find out dead pixels other than by looking at the monitor and searching for one?
Hi!,
I was wondering what are the possible monitor brands that are compatible on the windows 8 touch-screen features?.
I'm a windows 8 user and i think my monitor's brand does not  support the touch-screen features in the OS.
I hope to hear some answers,
Thanks in advance :)
Hi there,
I try to use HD44780 LCD Module to build a module. However when the simulate is trying to run, an error message appears and it says that the function set is incorrect. Please find below the screenshot of the error message for your reference.
Can any expert explain this error and any suggestion to solve the error? Thanks in advance.
Error! Function set incorrect. DL=1 N=0 F=0
Function set must be DL=0 N=1 F=0
I recently bought a 46" Sony KDL-46HX853 Fuul HD (1080p) SmartTV.  Is there a way to decrypt HD channels in comcast?  Can I also view the HD channels on my PC with AMD Radeon ROG ARES II dual HD 7970 6GB GDDR5?  Any suggestions on how to comcast decryption HD?
My dad bought Panasonic TH-42PWD4 for his room. He asked me to access the service menu. And yes, I did. What we are looking for are the descriptions for the service menu. Do anyone know some sites where Panasonic service menu explanation for TH-42PWD4 is available? Thanks.
Hi techyv,
What is all about the green line across screen? My dell laptop is having this green line across the screen and I cannot concentrate while doing my online business work. I have to get rid of the green line, but how? Is this has to do with my laptop LCD? I need some advice.
Hoping for your help. Thanks.
What is the compatible format music downloads for tablet? I have to be aware on the formats that the android table will only accept to avoid confusions and error. I want to consult some experts before proceeding to the next step. I am still on the planning process.
Kathryn Masud.
Hi there,
The sapphire HD pro I have installed in my g-card came with an s-video output. The card has the colors blue and green on it. Now, I want to join it to my HD-TV. Can I go ahead with the union so that I could use my vista media center? What am I missing here? Thanks for helping me out.
What wouldbe the optimum resolution for playing games on an LCD screen without overloading the PC which would make it atuomatically shut down.
My housemate recently bought an LG Smart TV. When he tries to open YouTube a pop message appears saying we need to download the latest version of flash player. We download it directly from TV. But nothing happens after a while. We can still view YouTube. It seems flash player 10 for LG Smart TV is not working. Do we need a specific version?
