Hello TechyV!
I am looking for Visual FoxPro header color change sample codes. Can anyone please help me? I am using Visual FoxPro version 8 and I am trying to change the color of my grid header but it’s not working. Can anyone please tell me what is wrong? If you have tried this before, then please guide me. If you have a working code, please share and let me know how to use it on my program. Any help from you will be much appreciated.
Thank you in advance.
- 106 reads
- 1 comment
Hi experts,
I am using Visual Fox pro data my work. I want to convert Visual Fox pro into BDE. I am looking for converter software or any tool to do this. If you know vfp and bde and also its conversion, then please help me out.
Thank you
- 166 reads
- 2 comments
Hi everyone,
I am working with some types of database related job. Specially it is FoxPro database. I need ribbon FoxPro for my job. Can anyone which one is best and how I can download it?
- 102 reads
- 2 comments
I faced a problem with my FoxPro database trace when I tried to open an ODBC connection as it keeps returning an error. Error says, Server Error which occurred while retrieving the list of Databases from & the server returned a non-specific error.
- 187 reads
- 2 comments
Hi Experts,
While importing legacy WinCASA data I received an error message. It says, “Foxpro driver does not support this function”. I tried several ways to get a remedy of this issue but no result. I also visited several sites but no solution. If you have any idea to solve the problem, please help me to get a remedy of this issue.
Thanks in advance.
- 141 reads
- 1 comment
II have developed programs and it runs fine for me, but when I tried it to run on my client's PC it gives me this error, I've copied the files that is needed to the client PC, any idea what I'm missing?
- 404 reads
- 2 comments
My foxpro 2.6 is now giving some error message. When I use DOS for opening this software I am getting an error message which says "Program too big to fit in memory". And then it returns to cmd prompt. I need a solution for this problem.
Please give me some reply.
- 444 reads
- 1 comment
- « first
- ‹ previous
- next ›
