Display :
Did not find what you want,
Be the first to ask question on Apple
Category: Apple
I had Cydia installed on my iPhone 3GS but suddenly that feature was gone. I don't know where it went but I want it back. It provided many utilities and useful apps like Slidetocall application that always confirmed before making any call. I am missing Cydia badly and curious to know if it can ever come back? Please suggest alternatives.
Category: Apple
I have seen Apple Claiming that it has reduced the Anti Glaring effect in its iPad, TV, Macbooks Displays. What actually is the Anti Glare effect. Is only Apple working on it or other companies too? What is the benefit of this effect. What if, if this effect is not controlled. Does it affect eyes? What makes it different from other technologies?
Category: Apple
I am getting lots of System program problem detected error on my desktop. If I Report the problem nothing happens and I still get these errors. Does anyone have any idea about this error ? Why I have this kind of errors ?
Thank you experts !
System program problem detected.
Do you want to report the problem now?
Category: Apple
Hello experts !
Every time this error appears when I want to install some programs downloaded from the Internet. Sometimes it appears and sometimes not. Any solution for this error ? Why I cannot open all the programs to install them ?
Thank you !
“New App” can’t be opened because it is from an unidentified developer.
Your security preferences allow installation of only apps from the Mac App Store and identified developers.
Safari downloaded this file today at 12:38 PM from example.com
Category: Apple
Hi there,
This is the error that AirPort gives me every time since I updated the driver. I don’t know how to roll back the new install or how can I solve it. Can anyone help me please to fix this error ? Should I reinstall the older version of the driver ?
Thank you experts !
An error occurred while reading the configuration.
Make sure your Apple wireless device is plugged in and in range of your computer or connected via Ethernet and try again. (-6728)
Category: Apple
I restored my computer yesterday and it was working fine. This morning after booting, now I am receiving an error message that won't go away even when I click 'Ignore'. Can anyone help me please to fix this error ?
Thank you !
Check with the developer to make sure mdmclient works with this version of OS X. You may need to reinstall the application. Be sure to install any available updates for the application and OS X.
Click Report to see more detailed information and send a report to Apple.
Ignore
Category: Apple
I have checked the URL many times and I have entered it correct. I don’t know why I cannot open it and what could cause this. Does anyone have some free time to help me with this ? Please help me to skip it and how can I prevent it to appear in the future ?
Thanks !
“Developer Lives” does not seem to be a valid Podcast URL.
Please check that you have entered the correct URL and try again.
OK
Category: Apple
It's been three days now since I tried and failed to answer the my apple ID security questions. I keep trying different answers, which I think is correct but nothing seems to be correct yet. Is there a way for me to reset the answers to my apple ID security questions?
Category: Apple
Hi everybody,
I have an Apple products iPhone, iPad and Apple TV as I like Apple products very much. I am able to play whatever I want in Apple TV except one thing. When I play/view something in iTunes on Apple TV, it tries to display the same but it hangs or it restarts. I don't think this is an issue with my internet connection because I am able to play the iTunes from iPhone and iPad with out any issue. Does anybody have a solution for my problem? Please throw some light on this issue.
Thanks a lot guys!
Category: Apple
Hello experts,
I get this below error message often whenever I try to connect to a BlackBerry 10. For your information, I tried through Bluetooth, then I tried to reconnect the device and retry but nothing helped me. How do I fix this error message? Please guide me. Thanks a lot.
Application Loader
Failed to connect to a BlackBerry 10 device. Please reconnect the device and retry.
